How do I fine Rx network ID
Fire25pfd
Huntington
Can anyone on here can help me I'm trying to fine the Rx network ID suffolk pd I'm trying to program my xts3000 and whats DEC/HEX
rbrtklamp2
Dupage County, Illinois
It stands for decimal and hexadecimal and may be a sign you are in over your head. The rx network ID is NAC as listed on the radio reference database for your system.
jaspence
Michigan
RX ID
Make sure that you also disable transmit and make sure your radio cannot accidentally associate with the system. If these things don't make sense to you, then you should either use a regular scanner or take the radio to a professional shop for programming if you can find one that will do it.
Fire25pfd
Huntington
I don't want to transmit I have an understanding of DEC/Hex I watched a video how to do something's. RX ID its used by the HEX right
RayAir
But can I put LTR system as conventional channels jaspence
You can conventionally scan the LTR frequencies in your commercial radio but you won't be able to follow one particular TG.
Best to buy a scanner that has auto LTR so you don't have to have the freqs programmed in LCN order and you can hold on a TG and just hear that one.
I think the PRO-92 handheld had auto LTR.
RayAir
Also, if it's Passport, you won't be able to follow TGs but you can conventionally scan the freqs still.
