Since this involves two different systems, I'll post here, in the generic trunking forum. I'm not the one who will be implementing the solution, but I'm looking to see if there is a better way to do this.
Here is the scenario: A Harris P25 system and a Motorola TRBO system across town. Have four existing talkgroups on the Harris side gatewayed to four new talkgroups on the TRBO side.
The obvious method would involve using four TRBO radios connected to the Harris interop gateway, with analog audio in/out of the interop gateway.
Is there a way to connect the two systems via IP and eliminate the four TRBO radios and the analog conversion? Obviously, this would require something that can speak the TRBO protocol and also talk to the Harris interop gateway. Does such a thing exist?
Thanks.
Thanks.
