XPT vs Mototrbo
hamtrektng
Plymouth, UK
Hi,
Can someone enlighten me to this question. With Hytera's new trunking system XPT (eXtended Pseudo Trunk) is it compatible with a Mototrbo Cap+ system which seems similar in regards to setup using CPS? Talkgroups 1 to 254, All Call 255 and emergency 250 are in effect capacity plus groups
Forts
Mentor
Ontario, Canada
You don't choose a timeslot in Capacity+ either, but the end result is the same... totally different protocols.
JRayfield
Springfield, MO
You don't choose a time slot with Capacity Plus, either. Both operate very similarly, including the capability of trunking the two slots on one repeater (a single repeater 'trunking system'). But other than operating in a similar fashion, they are not compatible with each other.
John Rayfield, Jr.
With XTP, you do not choose TS1, or TS2. The repeater chooses which ever is available. Totally different.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Cap Plus Is proprietary to Motorola just like XPT to Hytera and Simple Repeater Dual Slot to Simoco.
