Originally Posted by gkovar
Dick,
Thanks for the info...
Scanner was trunking correctly, however signal strength was really bad. ...
After grabbing the scanner and laptop and moving upstairs things are working fine.
Guess it's time for a trip to the antenna portion of the board. ...
... when I have my trunked system programed correctly I should just get no audio at all correct?
That will do it every time.
That will also do it every time. Height is great medicine.
This works pretty well. Also try a telescoping top element and extend it to multiples of 3-1/4"; 6-1/2", 9-3/4", 13".
http://www.pbase.com/dickh/image/27104369
Also, the Radio Shack 800MHz rubber duck works very well. RS #20-283 ?
NOTE: Since 1/4 wavelength is only 3-1/4", moving an antenna around just a few inches can make a huge difference.
Right - just the normal voice channels.
