Greetings all -
Can someone refresh my memory - did I hear something at one point that the 800MHz band plan had two different starting points? I have found some lists on various licenses in the Canadian Technical & Administrative Frequency Lists (TAFL) - the Canadian version of the FCC's license database - which have channel numbers listed in the extended info of each frequency on the license. Take this one as an example (but have Acrobat ready, as it's a link to a PDF) -
https://sd.ic.gc.ca/pls/engdoc_anon/...lic_no=4958723
Note the "Block x, Group y, Channel z" in the right-most column of each frequency assignment. For example, 858.0625 is designated channel 283. However, in the band plan I'm most familiar with, the one most commonly used in programs such as Unitrunker, MTrunker32, and as indicated elsewhere, ch 283 corresponds to 858.0875 - 250 kHz higher. Overall, it seems that the plan Industry Canada is using has channel 1 at 851.0125 with 250 kHz spacing, and the plan that Motorola et al uses has channel 0 at 851.0125, with 250 kHz spacing.
Which is "right"?
I'm not in range of the systems I've found in the TAFL with these channel numbers identified. Is it likely that trunker type programs (and/or scanners' internal software) will report incorrect values for either freq or channel if used on these systems?
If this doesn't make sense, I apologize - it is 2:45 on the first of two night shifts, after all.
