Originally Posted by wayne_h
I'm sure we'll see MOTOTRBO in the distant future. Right now it's not worth the cost for R&D and implementation in to a radio scanner.
We may be likely to see Icom and Kenwood's NXDN digital format in future scanners if NXDN takes off and becomes popular. NXDN is the competitor to MotoTRBO toward meeting the future 6.25kHz narrowbanding requirements for Part 90 services.
NXDN is FDMA, MotoTRBO is a 2-slot TDMA system. Although NXDN and MotoTRBO were designed from open European (ETSI) standards, it looks like Motorola did some customization of their solution (i.e., added 2-slot TDMA) in order to lock customers into using MotoTRBO gear supplied by Motorola.
With NXDN, you aren't locked into a single manufacturer (Motorola in the case of MotoTRBO).
