Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Trunking Forum
Trunking Forum General News and Information regarding trunked radio communications. This is the place to post general items related to trunked radio and technologies unrelated to the other forums. Location specific posts should be directed to the regional forums listed below.
Old 01-29-2008, 09:48 AM
Default Is FCC Mandating 700 MHz?
I currently manage a 911 dispatch center for a small police dept in MO. This morning our Police Chief told me he received a letter from a communications company out of St. Charles, MO which stated the FCC was making it mandatory for all public safety agencies to go 700 MHz by a certain time frame. Does anyone here know if this is true or not? I wasn't aware of any such mandate. I knew the FCC will require narrowbanding of the VHF spectrum by 2013, but I haven't heard anything concerning 700 MHz.
Old 01-29-2008, 10:55 AM
DaveNF2G's Avatar
The communications company is trying to sell you something. There is no such mandate.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 01-29-2008, 12:54 PM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
Wound be intersting to know what time frame they say as here in Mi, the MPSCS project which is slated to be done sometime around the end of the year is stepping down by 15 from the 86x area to the 85x mhz area but 700 mhz is not even on the horizen yet. I would contact someone at the FCC to see what the status is and advise the FCC on that letter. They might want a copy of it.
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Old 01-29-2008, 08:35 PM
I figured as much. Thanks for the clarification.
Old 01-29-2008, 09:21 PM
DickH's Avatar
Originally Posted by Skud
... in Mi, the MPSCS project ... is stepping down by 15 from the 86x area to the 85x mhz area ...
That is the second step in the re-banding process. The next step is the "gotcha" step where the band plan changes. If it is a Motorola system, older scanners will not be able to trunk track the system and newer scanners will need to be modified. Get ready for chaos.
Old 01-30-2008, 02:09 PM
here is the 1st step
http://www.800ta.org/content/documen...on_process.asp and you will see a FCC notice.
This is the 15mhz step down for the problem with sprint/nextel
ID Tracker Website
Old 01-31-2008, 12:30 PM
W4KRR's Avatar
And remember, the 700MHz band has NOTHING to do with rebanding.
Ken
Old 01-31-2008, 12:48 PM
Driv3r912's Avatar
Absolutley true - nothing but scams, or so .
The 700 MHz band does not involve the reband process - only 800 MHz. You are okay.
Catch Ya' Later!
Driv3r912
Old 01-31-2008, 12:58 PM
The FCC hasn't done much to screw up the 700 MHz band yet, so it is far too early for them to mandate anything. Give them time.
Old 01-31-2008, 01:45 PM
scansomd's Avatar
Do a google news search on "700 MHZ Auction". That will provide some insight on what is currently happenning. What is the next step after that? No one knows for certain.
An open message to PETA:
I never ate an animal I didn't like.
Old 02-03-2008, 06:42 PM
firescannerbob's Avatar
Um....my system is COMPLETELY done with rebanding, and our scanners work just fine. Just had to program in new Control Channels, and all is well.
-Bob
My online feeds, broadcasting Colorado Springs and El Paso County fire traffic, and the Colorado State Patrol in Pueblo and El Paso Counties: http://www.radioreference.com/apps/audio/?ctid=261
Old 02-03-2008, 06:53 PM
W4KRR's Avatar
What system exactly is this?
Ken
Old 02-03-2008, 07:39 PM
El Paso County, Colorado.
Also the Colorado Statewide system is almost done rebanding (they're doing the second touch right now), and again, no problems with any existing scanners tracking the system.
-Bob
Old 02-03-2008, 08:25 PM
W4KRR's Avatar
Interesting. All you did was to program the new control channels, and the scanner tracks the system with no problems? This seems to be contrary to what most people are saying would happen after rebanding. Let's see what happens when other systems get rebanded.
Ken
Old 02-03-2008, 08:33 PM
Absolutely. Any CC's we had that were above 860mhz were dropped below there (most by 15mhz. A few that were right at 860.XXX were just dropped 1 or 2 mhz). The new CC's were programmed into the scanners, and everything works as before.
The state of Colorado's DTRS system is undergoing re-banding with most of the sites already rebanded and almost every radio on the statewide system will be touched in the next 60days. DTRS sites that have been re-banded are also being tracked just fine.
If you need further, check the database for the new freqs, and then monitor my feed (below). It's a Pro-96 scanning the re-banded El Paso County system.
-Bob
Old 02-03-2008, 09:00 PM
W4KRR's Avatar
If you need further, check the database for the new freqs, and then monitor my feed (below). It's a Pro-96 scanning the re-banded system El Paso County system.
All I can say is I hope it's that easy when the local systems here are rebanded! Time will tell.
Ken
Old 02-03-2008, 09:32 PM
northzone's Avatar
If it is a Project 25 exclusive system (as both the systems mentioned above are) then rebanding is not a problem as frequency data is sent out the data stream. If it is a 3600 or mixed mode system, rebanding will required firmware changes to the radio (or use of custom tables).
Old 02-03-2008, 11:02 PM
There are only a handful of systems in the country on 700 and yes they are rebanding. Part of the auction going on required all 700 users to stop adding equipment after 8/15/2007. The winner of the auction will be required to pay for the rebanding the same as Nextel. The Colorado State system is included in that rebanding.
http://hraunfoss.fcc.gov/edocs_publi...C-07-132A1.pdf is the report and order from the FCC mandating rebanding
Old 02-05-2008, 10:16 AM
There is no rebanding mandate at 700Mhz. Period.
MASTRTECH
Old 02-05-2008, 02:22 PM
REDave's Avatar
Firescannerbob and MASTRTECH are both correct. The only reason that your scanner would not work in the 800 mhz band after rebanding is if it is not capable of receiving in the 850 mhz range. It is my understanding that the only the only frequencies effected are 865 - 870 mhz. So if a control channel now is 866.6175 it will be 15 mhz lower 851.6125 mhz. So if you subtract 15 mhz from your current control channel you should be in fine shape after rebanding
Encryption. It is a very excellent tool indeed.
Similar Threads
IMPD On Illegal tac frequencies 156Mhz W9NES Indiana Radio Discussion Forum 150 03-01-2008 03:51 PM
RS 800MHz antenna on BCD396T for 700MHz trunked systems? somery Antennas and Coax Forum 12 03-28-2007 04:12 PM
Very Ambitious FCC Plan For 700 MHz logitec Colorado Radio Discussion Forum 1 12-29-2006 05:30 AM
MPT system in Mohegan Sun Casino Unitrunker Connecticut Radio Discussion Forum 11 07-09-2006 10:11 PM
vhf/uhf landonjensen General Scanning Forum 3 07-06-2006 09:31 AM
