Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #41 (permalink)
Old 03-14-2017, 1:10 AM
Signal-Zero's Avatar
Give me a T...give me a D...give me a M...give me an A.......
"We celebrate our independence from the Government, not our dependence on it."
  #42 (permalink)
Old 03-14-2017, 2:50 AM
Alert to a specific call page ID number
  #43 (permalink)
Old 03-14-2017, 5:27 AM
krokus's Avatar
They do alert on specific talkgroups.
Sent via Tapatalk
  #44 (permalink)
Old 03-14-2017, 9:54 AM
Correct the issue where the unit skips transmissions if it misses the channel grant. This situation happens as much as 20% of the time for me. Confirmed by two scanners and Pro96Com logs.
  #45 (permalink)
Old 03-14-2017, 10:09 AM
I concur. Late entry would be a good fix.
  #46 (permalink)
Old 03-14-2017, 4:49 PM
wizard of odd
Sent via Tapatalk
Maybe he means radio ID page.
  #47 (permalink)
Old 03-25-2017, 7:38 AM
ffemtrfc1's Avatar
Wants: Moto Type II Smartzone
This pager currently ins't compatible with my local County system.
  #48 (permalink)
Old 03-27-2017, 7:28 PM
jtech48's Avatar
Ability to change the MDC ID display from Dec to Hex
In Flying, Carelessness And Overconfidence Are Usually Far More Dangerous Than Deliberately Accepted Risks
WQOE503
  #49 (permalink)
Old 03-31-2017, 4:45 PM
Hooligan's Avatar
Maybe this isn't new info, but...
I spoke to a rep at the Unication booth during the International Wireless Communications Expo this week in Las Vegas. P-25 Phase II capability is on the way, but likely not available until this Fall. It will be a software/firmware update that you can download & install, but yes, there will be a cost for it, as Unication had to license the intellectual property.
I also thanked them for their willingness to work with 'scanner-geeks' in addition to public safety members.
I am the King of All Monitoring.
  #50 (permalink)
Old 03-31-2017, 6:59 PM
What about those of us that purchased a G4 a year ago for $850 and now there going for $650. At the time a Phase II update was coming soon and would be free. Now a person can buy one and the update and end up paying less than I did with out PII. This makes a lot of sense. !! Shouldn't the gini- pigs be grandfathered in for PII?
  #51 (permalink)
Old 03-31-2017, 7:13 PM
I think us early purchasers should be "beta-testers" for Phase II.
  #52 (permalink)
Old 04-01-2017, 2:57 AM
troymail's Avatar
Hopefully, none of this is just something I haven't figured out how to do yet (I am only 2+ days into using the radio and software). I know it's a pager so I'm try hard not to push to many requests that sound like scanner features (but I do list some).
Radio
  • TDMA
  • Correct "sluggishness" when changing switch positions (seems to get more and more sluggish as more programming is added)
  • allow mixing of conventional and trunk talkgroups in a single "scan" list
  • ability to export recordings
  • more control over the main screen data for a system talkgroup (i.e. site name vs. RFSS/Site numbers)
  • additional (working?) "wildcard" options (all F's don't seem to work and cannot set Monitor mode via software - only on the radio)
  • ability to select the site (or sites) of a system to monitor without separate or duplicate programming
Programming Software
  • Improved bulk import/cut and paste options for adding system/talkgroup data
  • Improved talkgroup data organization
  • ability to "move" programming around/up/down (zones, switch settings, etc.)
Unication G5(UHF)
  #53 (permalink)
Old 04-01-2017, 5:36 AM
BenScan's Avatar
Try right-clicking with your mouse in the programming software, in the zones. You can move entire zones up or down. You can also copy and paste channel position.
There was a beta software program for downloading recordings to your computer. I don't know if they're still sharing that or not.
Radio
  • TDMA
  #54 (permalink)
Old 04-01-2017, 5:45 AM
troymail's Avatar
Ah - that helps alot... particularly if you programmed without a ton of planning in advance...
So - scratch that one off.
EDIT: found recording backup software also
Unication G5(UHF)
  #55 (permalink)
Old 04-01-2017, 10:42 AM
[*]Improved bulk import/cut and paste options for adding system/talkgroup data
I haven't found cut/paste to work well at all. How are you importing anything other than .unipps files?
  #56 (permalink)
Old 04-01-2017, 10:47 AM
troymail's Avatar
I'm not really.... just cutting and pasting talkgroup id and talkgroup names one row/cell at a time - and disabling the default tone setting.... very tedious... I'm sure there is (or can be) a better way.... I've now created over 500 talkgroup rows (for multiple systems) one row and cell at a time...
Unication G5(UHF)
  #57 (permalink)
Old 04-01-2017, 10:51 AM
Ok gotcha, same here. Add to the list the ability to choose +default or +current when adding talkgroups or systems etc like other software does. No need to keep setting fields that are the same for each new line.
  #58 (permalink)
Old 04-02-2017, 5:07 PM
Homeboys-Scanna's Avatar
Do the G4 / G5 still have no scan delay? So once a talk group carrier drops off, the unit immediately starts scanning so you end up hearing a mixture of unrelated conversations?
"Copy, 132 and Bush, cover's code 3."
  #59 (permalink)
Old 04-02-2017, 6:54 PM
Scan delay is NOT user defined so yes, if you monitor several talkgroups on a busy system it may scan off to another talkgroup.
  #60 (permalink)
Old 04-02-2017, 7:00 PM
That really sucks. For me, that basically ruins the scanning. So it's really only good for parking it and monitoring a single talk group. Everyone keeps saying how great these things are, but no one seems to mind the lack of scan delay? Why??
