Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
  #81 (permalink)
Old 04-16-2017, 2:29 PM
A big bold underlined frikkin AMEN TO THAT. The quality of my 32 year old built like a tank scanner still blows away any newer scanner made by any manufacturer. It came from a day when they cared more avout making a quality product than they did about making a quick buck.
  #82 (permalink)
Old 04-16-2017, 5:43 PM
There is the possibility that the scanner manufactures can not come up with a work around that doesn't infringe on patents or they just aren't willing to justify the cost or are just plain unable to get the required licensing for the RF tech needed.
  #83 (permalink)
Old 04-16-2017, 7:35 PM
Homeboys-Scanna's Avatar
Is there a way to power a G5 off a cigarette plug in a car?
"Copy, 132 and Bush, cover's code 3."
  #84 (permalink)
Old 04-17-2017, 6:38 PM
Signal-Zero's Avatar
Yes, power and charge.
"We celebrate our independence from the Government, not our dependence on it."
  #85 (permalink)
Old 04-18-2017, 8:34 PM
https://www.amazon.com/AmazonBasics-.../dp/B00Y07GULM
  #86 (permalink)
Old 04-19-2017, 1:49 PM
ecarvalho's Avatar
Could I add having the ability to import a system from RR or perhaps a csv file into PPS.
Icom IC-PCR1000 / BCD536HP / GRECOM PSR-800 / BCD996P2 / TRX-2 / Unication G4 & G5
  #87 (permalink)
Old 04-21-2017, 10:06 AM
PVPD730's Avatar
The only two changes I would like to see are
1) Encryption muting.
2) Implementation of Phase II (I know, I know...it's said to be coming out at some point; possibly later this year).
Aside from those two things, I personally don't feel anything else needs to change. Being that the Unication devices were never designed to be scanners, I can live without the talkgroup "hold" function and other bells and whistles that Uniden and Whistler offer. My G4 is like a dream come true for monitoring simulcast systems.
  #88 (permalink)
Old 04-21-2017, 10:35 AM
troymail's Avatar
What he said - particularly the last line.
Unication G5(UHF)
  #89 (permalink)
Old 04-22-2017, 9:53 PM
RRR RRR is offline
Just because it "wasn't designed to be a scanner" doesn't mean very useful features like selectable TG hold time and TG skip/lockout and selectable ENC muting or sound emitted aren't desired.
I love mine too, but I still want product improvements like just about every electronic gadget gets these days.
  #90 (permalink)
Old 04-29-2017, 12:24 AM
I think a TG Hold and a TG Delay time setting would be easy enough to do and would LOVE to see this at least!
SDR | UNICATION G4 | TRX-2 | TRX-1 | BCD536HP | BCD436HP | HOMEPATROL-II | BCD996P2 | PRO-197 | PRO-106 | BCD396T | BR330T | IC-R2
  #91 (permalink)
Old 06-19-2017, 3:10 PM
For P25 trunked systems, a way to add a range of talk group id's.
In my system of interest, patched transmissions occur over a range of tg id's. At any given time when a patched transmission occurs, they can use any of the 150 or so, tg id's, dedicated for this purpose. The pager has a limit on the amount of tg id's it can listen to. If I went ahead and try to program this range, I'd run out of room for other tg id's.
In a scanner, there's no need to program each and every tgid, it will automatically listen to a patched transmission.
Monitor mode won't work for my purposes as MM listens to ALL active tg id's.
  #92 (permalink)
Old 06-19-2017, 9:09 PM
KB8KOJ's Avatar
A Lockout and a Hold during scan and MM would add tons of usability.
  #93 (permalink)
Old 09-19-2017, 3:41 PM
k7aab's Avatar
Default What I would like to see
1) More robust audio - audio circuit needs to be of better quality (the fire service is not always quiet)
2) The pager is still missing traffic on our Motorola Type I system , that I can hear clearly on our police radios. 100% copy is key for public safety use
3) Needs a AGC circuit toggle option in menu - many p25 systems do not discern between low and high audio ie; I can hear dispatch loud and mobiles and potables are hard to hear with volume adjusted down.
  #94 (permalink)
Old 09-19-2017, 5:56 PM
k7aab's Avatar
I forgot to add;
4) audible hiss when receiver opens (first pager in 33 years I have used that has done this)
5) pager sits awkwardly in amplified charger, belt clip does not lock onto charger as designed, intermittent connection with pins.
  #95 (permalink)
Old 09-20-2017, 1:14 PM
RRR RRR is offline
PHASE 2 !!
  #96 (permalink)
Old 09-20-2017, 7:59 PM
davidzimmerman's Avatar
PHASE 3
  #97 (permalink)
Old 10-24-2017, 11:13 PM
What I would like to see. Yes, I've seen this in other places; BUT I am just 'throwing my 2 cents in' and making the request too . At this point, this device is somewhat 'useless' for me (and apparently others who also are requesting this feature).
1) I want to be able to SCAN/MONITOR both a P25 System AND Analog at same time.
2) In addition to the above; able to SCAN/MONITOR (at least) '2' P25 different systems at same time.
Our department receives dispatches from (2) different Counties (as we are located on the border). The one is a P25 Motorola Phase I System; and the other county is Analog. So I either have to listen to P25 Only ; and hear dispatches thru just the one county .......... OR ........... switch off the P25 and Scan on the Analog Bank and listen to the 2nd County.
I have a XTS5000 Portable; and with the programming I have 'set-up' for Scan; I can do ALL 3 options above. Scan Analog and P25 (actually able to also Scan a 2nd P25 System in complete separate county as well).
When this device can do this; then I'll be totally thrilled (and I am confident many other users too). !!!
  #98 (permalink)
Old 11-06-2017, 12:14 PM
My number one request is late entry. I think that should be priority one because I often completely miss transmissions. Second would be Phase II.
Realistic Pro-22 | Uniden BC60XLT | Uniden BC246T | Uniden BCD436HP | Unication G5
  #99 (permalink)
Old 11-08-2017, 3:56 PM
Unication_David's Avatar
I have a version that fixes late entry. I was running more tests on it today and it works great the next release will have the fix in it.
David K. Oney
Unication USA, Inc.
817-210-4187
Please email rather than PM this will insure that I see your message. David@unication.com
  #100 (permalink)
Old 11-08-2017, 4:30 PM
Best news all week, David. Thanks for that update!
Jim
