G5 Broadcastify Feed
mswells
WB6JLB
Phoenix, AZ
Just curious if anyone is using a G4 or G5 to stream on Broadcastify......and if so....how are you feeding the audio to the input on the computer used to feed it, since there is no headphone jack ?
jeb2942
Hillsboro, Oregon
The easiest way would be to buy the Unication Charger Amplifier which has an output audio jack on it. I notice it's out of stock again at Scannermaster but Rayspagersales might have them.
jasonk
Dayton, OH
Yes - I am feeding a P25 system with Unication G5 - using the Amplifier/Charging base. Has been stable for several months.
Jason
rogress
Chesapeake, VA
Jason
Just curious, has anyone else hooked up a G4/5 to their Broadcasify feed since this was posted? I am going to try to do it with the audio output of the amplified base, but I noticed there is a significant "thump" associated with the squelch opening/closing, and it really makes it hard to use for a feed.
I may need to try to attenuate the output since it seems to be a speaker output and not a line output.
cpetraglia
Fairfax, VA
You'll never get rid of the thump. You'll have to find a compatible BT receiver that does not have any beeps or unwanted noises. BT wont work while plugged into the charger base. You'll need to keep the Pager powered by USB all the time along with the BT device.
rogress
Chesapeake, VA
Thanks - I suspected as much. I've got the feed up with the G5 and the thump is definitely there. Sometimes it sounds like a delay before the audio kicks in. (Chesapeake Police). I'm also experimenting with different levels of attenuation.
I've ordered a BT receiver and will be trying that.
rogress
Chesapeake, VA
An update on this. A bluetooth receiver has the same thump sound when the squelch opens/closes, so I decided to stick with the amplified charger to provide the feed.
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
Have you tried turning the volume down as low as possible? I read somewhere here that the BT will not work with the unit in the charger. I am following this as I am considering a G4 for my feed.
rogress
Chesapeake, VA
Yes, I did experiment with adjusting the volume. It actually seems best with a high volume since the level of the thump is constant.
All that being said, this is better than the the Pro 106 that I used to use, since the G5 doesn't have any issues with simulcast distortion.
If they ever solve the beeping bluetooth issues I'll try bluetooth again instead of the amplified base.
lifeson
Hilliard,Ohio
I am getting that thump from the amp base. How are you running yours now? Yours sounds great!
Thanks for any help
Danny
rogress
Chesapeake, VA
I did abandon the bluetooth solution and stuck with the amp base. I use an attenuation cable between the speaker output of the base and a USB sound card. It seems to help if I can turn the volume up on the base.
The thump isn't bad, but for some reason it does seem to cut out the first part (1/2 second maybe?) of some of the transmissions. Some side effect of going through the amp base and a USB sound card. I haven't spent time figuring out what causes that.
Thanks for any help
Danny
lifeson
Hilliard,Ohio
That’s a great idea. What dB cable are you using?
Thanks for your help.
WaveJam
Frederick, MD.
I'm getting ready to throw my G5 on my feed (just waiting for the base to arrive). Question, with your base pumping audio into the feed, can you still use that front speaker too? Or, if you have the audio cable plugged in, does it disable the front speaker? I like to listen in live sometimes rather than through the feed and it would be nice if I had the option to just turn on that speaker.
I'm worried about that thump noise but.. a little bit of thumping is far better than the cruddy audio I have now with my Unidens. :)
I pray. I pray. That the G5 will be supported with alphatags in the feed someday.
rogress
Chesapeake, VA
The speaker is off when you plug into the audio port. If I want to listing to it directly (not through the feed), I listen through the speakers that are plugged in to the computer which provided my feed.
mdsxfire
EDBM
Uxbridge, north of the river Thames
Just have to say listening to the feed it sounds great! The “thump” sounds more like a conventional repeater kicking off and isn’t bad at all
WaveJam
Frederick, MD.
I bought it a long time ago at Radio Shack, but I notice you can still find them on ebay:
https://www.ebay.com/i/381576852764?chn=ps&dispItem=1
I just ordered that cable. Hoping it helps some. I just put my G5 online and I'm getting that popping noise. Is this what yours sounded like before that cable?
https://www.broadcastify.com/listen/feed/9809/web
The popping is louder when listening from a mobile device. Ugh! This sucks. The simulcast prob is finally gone, now a new problem to face. :-(
rogress
Chesapeake, VA
Yes, that attenuation cable will help. It lets you turn the volume way up on the base/charger. Fortunately, the level of the thump stays the same as you turn the volume up on the base which seems to minimize the effect of the thump.
Someone said in another Unication thread that the amp doesn't kick in until it detects audio, which is what causes that thump. If we could tap in to a regular line out from the radio, bypassing the amp, I think this would work much better.
