Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 07-11-2017, 3:27 PM
Default G5 pin out
I'm trying to figure out the pin outs on the bottom of the G5. Long story short I want to use my amplified charger base as a charger only, and have the audio still come out of the pager. The amplified charger makes a "popping" sound every time the carrier drops off and drives my wife and I insane at night.
Old 07-11-2017, 6:23 PM
I know right? the amp is activated by carrier only which is a bad design.
Have you looked into the base manual? I can't right now but maybe there is some interesting info there
Yes, there are stupid questions. Don't ask them.
Old 07-11-2017, 8:53 PM
So no, the manual does not give information on the pager socket pin-out. I sent Unication support an email asking for perhaps the schematics.
I also need that info. I'm attempting to force the audio amplifier to stay on independently from the carrier. That should theoretically stop the popping. Might be a simple hack... or not.
Old 07-11-2017, 9:02 PM
Ok, great, sounds like a win win with either option. If you receive an update could you please post on this thread?
Old 07-11-2017, 9:03 PM
Sure thing
Old 07-12-2017, 7:33 AM
If you plug in an external speaker, the popping gets really loud. Not pleasant to hear.
Old 07-12-2017, 7:57 AM
Correct!
Old 07-12-2017, 9:42 AM
Ha, yea I tried that too. Worse off IMO.
Old 07-12-2017, 10:04 AM
I was told that the pinout for a G1 is the same for the G4/G5. I think it is attached.
Old 07-12-2017, 11:11 AM
Great, thanks for the pic, do you know what Vbat means?
Old 07-12-2017, 11:13 AM
voltage battery I would suspect
Old 07-12-2017, 5:47 PM
Has anyone tried tapping the audio/ground and if so how does it sound with a small ext. speaker?
Old 07-12-2017, 9:43 PM
Are we sure that pin reference from the G1 is the same for the G4/5?
Old 07-16-2017, 9:51 PM
I have verified ground, vbat and the charger detect pins. I built my own small drop in charger using those pins. I have not verified the others, but was told by someone at Unication (not Dave) that the pinout is the same.
Old 07-16-2017, 10:35 PM
Good to know. I haven't had a chance to open the base charger/amp from Unication. I want to mod it to stop the audio popping between transmissions.
Old 07-17-2017, 6:38 AM
krokus's Avatar
What did you use to make this?
Sent via Tapatalk
Old 08-26-2017, 5:39 PM
Just picked up a G5 so I'm very new to these but wondered too how you made a drop in charger. Could you share a few pictures please? VHF signal around here sucks so it would be nice to make something to drop it into and get it on a better VHF antenna without using the amp charger
Old 08-27-2017, 6:19 PM
krokus's Avatar
You could use a VHF antenna made for a Motorola XTS series, in place of the one that came with the pager.
Sent via Tapatalk
Old 08-27-2017, 6:33 PM
I need to improve the VHF coverage on the pager so if I understand what I have read the antenna connection is only good for the 7/800 band. Looks like if I could connect to the contacts on the bottom it would be for the VHF side. Would be nice to have sitting here on the table because the county VHF system is not good here
Old 08-27-2017, 9:40 PM
Sent via Tapatalk
You cannot. The antenna on the pager itself is only for the 700/800mhz band, not VHF.
