Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 07-18-2017, 4:09 PM
troymail's Avatar
Default Full Spectrum Scan bug?
I just created ("enabled") a Full Spectrum search configuration on my G4 - actually 3....
I created a Full Spectrum Scan that included 769-775 and 851-866 Mhz. I then "copied" that "system" twice and created one that had only 769-775 and another that had 851-866.
In a zone, I created one knob position for the 700 search, one for the 800 search, and one for the 700/800 search.
When running the search using the 800 knob position, it is finding the control channel for a nearby 700 mhz site.... why?
Unication G5(UHF)
Old 07-18-2017, 4:37 PM
Probably an image frequency. Only a guess without knowing the receiver IF.
de K3SLS Steve
Old 07-18-2017, 5:39 PM
troymail's Avatar
G4 is definitely showing a valid 700 CC frequency.
Unication G5(UHF)
Old 07-18-2017, 5:43 PM
What's the difference between the two freqs. in mHz?
de K3SLS Steve
Old 07-19-2017, 8:59 AM
troymail's Avatar
Ok - now I am seeing the opposite as well -- the knob configuration (700 Mhz search) I'm looking at right now is set to 769-775 searches for control channels. It's stopping and locking on VIPER site 3/7 (Bolivia / 856.6875).
Time to take a "dump" of the programming (raw) and see if I can figure out why this is happening. Perhaps the "copy" function - followed by removing one or the other frequency ranges isn't working properly.
EDIT: radio has now jumped to site 3/63 (Supply / 853.6125) - still supposed to be checking 700 Mhz range....
Unication G5(UHF)
Old 07-19-2017, 9:47 AM
Unication_David's Avatar
The unit is designed to receive valid CC info from the site in which it locks on and add it to its internal list. So it can lock on to a valid CC that is not in the Full spectrum scan range or programmed into the unit.
David K. Oney
Unication USA, Inc.
817-210-4187
Please email rather than PM this will insure that I see your message. David@unication.com
Old 07-19-2017, 9:49 AM
troymail's Avatar
That really makes no sense at all -- if I program the unit to search specific ranges but the radio thinks it is smarter than me, that's dumb.
Sorry -
Unication G5(UHF)
Old 07-19-2017, 9:52 AM
Its not that its smart it just does what the system tells it to do. If it says we are changing CC to a certain one that is not listed in the scan range or in its list it does what its told.
David K. Oney
Unication USA, Inc.
817-210-4187
Old 07-19-2017, 9:57 AM
troymail's Avatar
Unication G5(UHF)
Old 07-19-2017, 10:44 AM
KevinC's Avatar
Moderator---not censor
I'm "guessing" in full spectrum scan it will use the sites adjacent site list. So if you scan 800, it finds a CC and that site has a 700 adjacent site, it could go there. Just a guess though.
Someone told me signatures are silly, so I got rid of mine.
Old 07-19-2017, 10:59 AM
I think that's a darn good guess. Troymail…look at the Southport site freqs. They are in the range you are seeing.
de K3SLS Steve
Old 07-19-2017, 11:02 AM
troymail's Avatar
My thinking in the split is to control (limit/restrict) the radio to NOT pick up known CC frequencies -- in this case, it's a full range split (769-775 and 851-866).
For example, if I know there is a valid CC and system on 853.6125, create two ranges that are on both sides but exclude the known frequency -- seems like the radio will ignore what I'm trying to accomplish. The problem of course is that once the radio locks onto a CC, it's near impossible to get it to force the radio to "let it go" and look for something else.
Unication G5(UHF)
Old 07-19-2017, 12:11 PM
troymail's Avatar
Looks like the G4 is trying to be "smarter than me"... I created a fresh, new profile - two frequency ranges - one is 769-775 and the other 851-866. All WACN, SYSID, RFSS and SITE IDs are wildcarded...
I started with knob position 1 - a search of the 769-775 range - found the local site running on 700 mhz as expected. So far so good.
I then switched to knob position 2 - 851-866 search and it found another local site of the same system... fine job.
I then switched back to knob position 1 (700Mhz) and saw it find the expected 700 mhz site again.
I then walked inside the house - still monitor 700 mhz - and it apparently lost the 700 site and is now monitoring the 800 Mhz site - even though I'm switched to position 1 to search for 700 mhz sites....
Weird.
Unication G5(UHF)
Old 07-21-2017, 11:11 AM
It's part of the P25 standard.All P25 radios have a similar feature.For example Harris calls their version Enhanced Control Channel Scan.It allows the radio to find the system data when roaming without any user intervention by using the over the air adjacency tables that are broadcasted by the sites.It's meant to reduce programming the radio manually when WACN, SYSID, RFSS and SITE ID or frequency changes are made and keep the radio connected at all times. Most P25 radios have a preference table that allows you to choose which sites are more preferred, otherwise,the radio will switch to which ever site, based on the adjacency data it's receiving.
Old 07-21-2017, 11:16 AM
troymail's Avatar
Originally Posted by TDR-94 View Post
It's part of the P25 standard.All P25 radios have a similar feature.For example Harris calls their version Enhanced Control Channel Scan.It allows the radio to find the system data when roaming without any user intervention by using the over the air adjacency tables broadcasted by the sites.It's meant to reduce programming the radio manually when WACN, SYSID, RFSS and SITE ID or frequency changes are made and keep the radio connected at all times. Most P25 radios have a preference table that allows you to choose which sites are more preferred,but if those aren't within the set parameters,the radio will lock onto which ever site it can get data from.
Even if this is fact for the Unications (vs. speculation on how Unication devices really work), it defeats the concept of searches (wildcarded WACN, SYSID, etc. and frequency ranges).
Now, if I programmed a specific WACN, SYSID, etc., it would probably make sense to have it act this way -- but that is not the case.
Unication G5(UHF)
Old 07-21-2017, 11:36 AM
That type of feature isn't meant for 'scanner' type system info searching.It's a P25 standard for autonomous roaming.The sites tell the radio who it's neighbors are and all the associated system data it needs to keep the radio connected.
It basically overrides/ignores what you have programmed, except for the talkgroups and only uses the over the air data being broadcast about the system, from the sites, to tell it what to do.
