Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 01-16-2018, 1:56 PM
WaveJam's Avatar
Default Priority Talkgroup Functionality on G4/G5
Hi All.
I have a G5 and have a channel setup with about 40 TG's. Of that 40, I would like to have one set as priority. I see the "Priority Talk Group ID" option in the channel settings. But that means I'm prioritizing all channels based on the order in the list. Highest on the list = highest priority. But... I only want the one channel prioritized and all remaining channels treated equal. Is that possible?
Thanks.
Sincerely,
Pete
www.frederickscanner.com
Old 01-16-2018, 6:59 PM
No. All or none.
Old 01-17-2018, 12:40 PM
WaveJam's Avatar
Originally Posted by TwoWayTim View Post
No. All or none.
Bummer.. Thanks.
Sincerely,
Pete
Old 01-17-2018, 4:17 PM
Similar issue as WaveJam: I have a list of TGs assigned to single knob position, however, I'm still hearing EVERY TALK GROUP using the P25 trunking system. I've even tried assigning a single TG to a knob position. Same result.
If it is not possible to monitor just one TG, or list..., then I just purchased a very expensive paperweight
73's, Gordon -- W3GJJ
Old 01-17-2018, 4:37 PM
WaveJam's Avatar
In the Zone and Channel settings make sure you have the "Receiving Mode" set to TG-Scan and not TG-Monitor. I think thats the one you need. Could be wrong..
I can at least assure you that mine only scans the TG's I want, so I know its possible.
Sincerely,
Pete
Old 01-17-2018, 4:58 PM
trido's Avatar
I also have one TG in one knob position it is a Harris P-25 system and I only hear that one group.
Like He said be sure TG scan, it does work.
Jeff
Old 01-22-2018, 7:45 PM
Thank you very, very, very, (you get the point) MUCH for your input. Changing from "TG Monitor" to "TG Scan" did the trick. I've been programming scanners for 10+ years, but, without your insight, would have never thought "scan" actually means "monitor" a single TG on a pager. Go figure.
Old 01-22-2018, 8:08 PM
WaveJam's Avatar
Good. Glad it worked. Yeah, the PPS is a nice interface but I disagree with some of the wording they used. I think the choice for this setting should be “TG-Scan” to scan the selected TGs, and “TG-Search” to find and pick up all TGs. Monitor and Scan seem too similar to me.
Sincerely,
Pete
