Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 01-22-2018, 1:39 PM
62Truck's Avatar
Default G1 Long Tone Question
Before I get to my question here is a little background on how things are set up in my county when it comes to tone outs. My county uses Plectron Tones and the timing is 2 seconds by 1 second and 8 seconds for long tones.
My county uses a long tone of 1180 for Weather and Special Announcements. 1180 tone frequency is also used as an A tone for the commercial EMS agencies.
My pager is opening up prematurely when its set for Long Tone, it kind of acts like its set up for single tone instead. Is there a setting that I might be overlooking? Or may I have found a bug in the firmware?
Lions, Tigers, Bears....
Old 01-23-2018, 1:17 PM
62Truck's Avatar
105 Views and no help?
Old 01-23-2018, 1:36 PM
Your on a scanner forum. I would call Unication support.
Old 01-23-2018, 1:44 PM
mule1075's Avatar
This is the Unication forum he posted in.This is not a scanner forum only anymore.Scanner users are more common on radioreference yes but again this is the Unication forum on radioreference.
Uniden BCD536HPx2/250D Motorola HT1000/GM360
Old 01-23-2018, 2:02 PM
troymail's Avatar
Probably best to contact your vendor/sales outlet....at least that is what David has said for the G4/G5....
Unication G5(UHF)
Old 01-23-2018, 2:28 PM
w2lie's Avatar
New York DB Admin
I'm a Unication Dealer. Did you set the tone out table for Fast Plectron, or are you using custom timing?
Is the EMS dispatch on the same frequency as the Weather Alert Tone? If not, you might want to create a second tone table for just the EMS frequency and assign it that way.
The Unication G1 does follow timing, so if your A tone is long enough to trigger, you might need to adjust your tone table accordingly. Just because your tones are Plectron standard, it doesn't mean your tone lengths are.
Fast Plectron tones are .75 x .25 sec in length for A/B tones. For long tones, the timing slips my mind.
It sounds like you are using Motorola Timing for the length of your A/B tones, they are 2x1seconds
Try changing the table to Motorola timing and let me know how that works.
My Long Island Live Scanner website: www.w2lie.net
Providing RR with the following Scanner Feeds: NCFD | NCPD | SCFD | SCPD
For my Full list of Long Island Feeds & Remote Radio click here
Old 01-23-2018, 3:48 PM
62Truck's Avatar
Yes, Fire, EMS, and County Wide Alerts are transmitted on the frequency. I know the tone lengths aren't standard the county shortened them up back in 2007 or 8.
I do not see anything in the Tone Tables about timing, unless I'm overlooking something.
I did contact Unication Tech Support and this was the reply I received "Try changing the order of the stack of tones."
What I ended up doing was removing the long tone. There are a set of tones that are transmitted with that long tone and I placed them in instead.
Old 01-23-2018, 3:49 PM
62Truck's Avatar
Its "You're"
Old 01-23-2018, 4:02 PM
SteveC0625's Avatar
Originally Posted by 62Truck View Post
I do not see anything in the Tone Tables about timing, unless I'm overlooking something. .
Tone timing is determined by the Tone System you select. Motorola is 1/3 for a regular QC-II pair and 8 seconds for the Long Tone.
I have a mix of tones from Motorola and Plectron charts but they all use Motorola timing. Some are A/B pairs and others are Long C. I have 20 G1's set up like this and they work just fine.
Rochester-Monroe County 911 7010 1976 to 2003
Northampton Ambulance - Car 2829
KD2IAT --- WQPG808
Old 01-23-2018, 4:41 PM
Its "You're"
Thank you. I am on the Samsung and Google forums right now complaining about their phone and the auto correction capabilities. The latest firmware release should know what I am trying to type.
Old 01-23-2018, 6:53 PM
This might be a useful resource: https://www.midians.com/pdf/tone-signaling-charts.pdf
de K3SLS Steve
Old 01-23-2018, 7:35 PM
w2lie's Avatar
New York DB Admin
Go into PPS and click on Tab F. From there click on the tone table you are using.
You'll be presented with the screen that you can enter your tones.
At the top, you can pull down the timing.
Pick Motorola. I'm almost certain that will fix your problems.
Old 01-30-2018, 1:38 PM
62Truck's Avatar
I switched it to Motorola and everything seems to be working as it should when it comes to long tone. After RTFM I noticed that the timing for Plectron long tone is 3 seconds and that is why I was getting the premature alerting. One thing I want to point out is that we are indeed using Plectron tones when it comes to tone frequency. So one thing that had to be done was I had to select Plectron first, input the tone frequencies and then change paging system from Plectron to Motorola.
Old 01-30-2018, 3:59 PM
SteveC0625's Avatar
You really don't need to set Plectron to enter the tones and then change to Motorola. If you set it to Motorola to start, and then enter your Plectron tones, the software will adjust the tones a tiny bit. My 1130/992 gets converted to 1129.7/991.3 and works just fine. These tone decoders can handle about a half % variation in frequency with no loss of proper decode.
KD2IAT --- WQPG808
Old 01-30-2018, 7:19 PM
62Truck's Avatar
Thanks for the info. Good to know!
