Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 03-14-2018, 1:49 AM
Default Reception Paging
Hello all,
I got my codes for two tone programming from the county. The pager seems to go off when it feels like it it has to be in a certain spot or area to go off. Yes the anplified charger will help at home but what about when I'm out? What can I do to fix this? Dave any recommendations?
Old 03-14-2018, 10:12 AM
is the paging done on a P25 system? what band?
Is it done on a conventional analog channel that uses the pagers secondary antenna, if your referring to a G5 and not a G4.
This sounds less like a two tone issue and more like a general reception issue.
How strong is the signal your tones are being sent on?
Old 03-14-2018, 10:51 AM
Question
500mhz band conventional and it is in fact a g5. The signal usually has anywhere from 1-3 bars on it. I can have my radio sitting right next to it with dispatch channel going off and the pager doesn't do anything.
Old 03-14-2018, 6:19 PM
mdsxfire's Avatar
Is the squelch setting set to high? And isnít there a setting for tone duration long vs short type of tones?
Old 03-14-2018, 6:41 PM
There is something for the duration which is set to standard motorola paging system and the squelch setting is set to low.
Old 03-15-2018, 2:44 PM
Yes there are several different tone lengths, Motratola quick call 1 and quick call 2 are very common but there are may different lengths. My department uses quick call 1 indiviual call tone & voice. my pager is set for QC1 and CSQ squelch and it works just fine. I would try to find out from a system admin what tone system you use. or maybe try to record the tones and time them then refrence the chart found in the link below to see what tone system they use.
https://www.midians.com/pdf/tone-signaling-charts.pdf
Old 03-15-2018, 7:19 PM
We use a 2 tone system my pager is set up two tone csq I talked to one of the guys from 911 center they said it is a standard Motorola paging system
Old 03-15-2018, 7:44 PM
Eng21inefd- First, is the pager showing 1-3 bars consecutive or when they are "toning out"? Second, do you have a pl or dpl set for your dispatch frequency? Also are you scanning multiple dispatch channels as silent scan?
BNN#13
Erma FD
Cape May City FD
Old 03-15-2018, 8:45 PM
No lockout codes at all. And the only things that I'm scanning is ems fire Dept and fire police and it's all on the same channel knob it even does it with just my fd knob
Old 03-16-2018, 7:40 AM
Eng21inefd- If you can send me your codeplug I can take a look.
BNN#13
Erma FD
Cape May City FD
Old 03-16-2018, 10:13 AM
That is the codeplug, i literally cant figure this out.
Old 03-17-2018, 9:55 PM
Eng21inefd- I just emailed you back your codeplug. Let me know how it works.
BNN#13
Erma FD
Cape May City FD
Old 03-27-2018, 5:21 PM
I have the same problem.
My fire channel works intermittently.
Tonight I had it set on and the pager crashed and rebooted.
