Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 04-16-2018, 1:26 PM
Default Attempting to do a first programming on a g5
I have the G5 uhf d-700
I am attempting to download my radio plan and this message pops upĒ The protocol of the device is unspecified. ď . I donít understand why or how to address it. Any help thank you
Living the dream
Old 04-16-2018, 1:32 PM
troymail's Avatar
Silent Key
I am attempting to download my radio plan and this message pops up” The protocol of the device is unspecified. “ . I don’t understand why or how to address it. Any help thank you
Make sure you are using the PPS that matches/is associated with your firmware. Each firmware release comes with it's own PPS version.
Then, make sure you have selected the correct model from the pull-down list in the PPS. In most cases, the models at the top of the list of the ones you want.
Note: if you selected the wrong model for your profile, you should be able to create a new one and convert what you have to the "new model".
EDIT: I just pulled the battery from my G5 for "other reasons"... There is a model number listed inside the battery compartment... I believe the model number is on the box your radio shipped in also.
Unication G5(UHF)
Old 04-16-2018, 1:40 PM
Unication Representative
You have not specified a protocol in D 3. Watch this programming video.
https://www.youtube.com/watch?v=yijWstvoEn8
Old 04-16-2018, 2:04 PM
So when I unboxed it someone else was here and took the card off that says “go to this website and download the pps” �� anywaysLools like I’ll be good to go here. Thanks for helping !
Living the dream
Old 04-16-2018, 2:06 PM
troymail's Avatar
Silent Key
So things are working? Great!
Unication G5(UHF)
Old 04-16-2018, 3:00 PM
yes i am programed. now i can't figure out why it is not opening the audio unless i push to listen. I have unchecked push to listen in each zone
Living the dream
Old 04-16-2018, 3:04 PM
troymail's Avatar
Silent Key
See: http://forums.radioreference.com/uni...ml#post2912544
Unication G5(UHF)
Old 04-16-2018, 4:55 PM
LEH's Avatar
LEH LEH is offline
Double check your settings in the PPS, also check each zone and knob selection. I've had the 'push to listen' problem a couple of times after doing changes to my programming. I am not sure if the problem is 100% self inflicted, a 50/50 between the PPS and me, or if the PPS just like arbitrarily changing some settings.
What I think happened is I was using my mouse wheel to scroll down to the page in the knob settings tab. When the arrow got over one of the 'drop down' windows, the scroll changed the setting and then moved on.
As far as I can find, the 'push to listen' is knob position (channel) unique. So check another channel for activity and sound.
Lynn
Old 04-16-2018, 11:22 PM
Originally Posted by troymail View Post
So this worked. I was searching for that post because I had seen it so thank you. Now I canít get any of my digital trunk stems to scan. Not one. I live in a rich area of systems so being out of range is total BS.
Living the dream
Old 04-17-2018, 12:10 AM
System ID WACN were backwards! Ugh this little thing is the most complex yet simple thing I have ever programmed!
Living the dream
Old 04-17-2018, 5:56 AM
mdsxfire's Avatar
It gets much easier with time and practice as with most things, and is def worth the results!
Old 04-17-2018, 12:48 PM
LEH's Avatar
LEH LEH is offline
I have a couple of systems in my area that will work one day and not the next. For them I've used the wildcards for System ID and WACN (all "F's"). This seems to work as when the control channel is received the ID and WACN displayed are correct.
As Troymail and others have said, the RR DB information is not always correct.
Lynn
Old 04-17-2018, 10:51 PM
For my next question....
Every time anyone keys up to talk on the Monmouth county system, it makes a tone alert cutting the audio out. Any idea what is going on here?
Living the dream
Old 04-18-2018, 1:50 AM
krokus's Avatar
Push to listen is set per knob position.
Sent using Tapatalk
Old 04-18-2018, 1:51 AM
krokus's Avatar
You have that TG for tone alert, instead of none.
Sent using Tapatalk
Old 04-18-2018, 10:59 AM
Sent using Tapatalk
This issue was already solved. The alert was set to silent which wouldnít allow any transmissions to come over.
Living the dream
Old 04-18-2018, 11:22 AM
Thumbs up
Sent using Tapatalk
I just found this setting, it was in fact on default. Switched back to none. To everyone helping and replaying to me making bone headed mistakes, thank you. I haven’t had this many problems programming a radio/pager in a long time!
Living the dream
