Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 07-09-2018, 10:29 AM
Default Site Tracking
If I program multiple sites into the G5 for a single site will the pager automatically switch between which one it can pick up best or does it wait until it drops signal from the first one it locks on to?
Old 07-09-2018, 11:03 AM
Best one
Sent from my SM-N950U using Tapatalk
Old 07-09-2018, 2:04 PM
dseven's Avatar
Originally Posted by hou30guy View Post
Best one
You know this for sure?
To do this, it'd have to retune to each periodically to see if there's a new "best". How often does it do that?
Old 07-09-2018, 4:52 PM
troymail's Avatar
If programmed with multiple sites, the radio will find a site of sufficient signal quality and stay there until the quality drops and then it will look for something better.
I see mine switch once in a while between the two closest sites of my statewide system... occasionally (very rare), it switches to a more distant site in the county but for a very brief time.
The radio does it's best (pretty good in my opinion) to lock onto the best site but that can be affected by many things - one being which antenna you are using.
To have more positive control over the site you monitor, you can create multiple 'systems' which include only a single site.
Unication G5(UHF)
Old 07-09-2018, 5:30 PM
I have the entire First system hmtjat covers the upper Eastern Shore of Maryland programmed and it seems to be doing well. Although I managed to turn off every department and can't seem to get any department turned back on.
Old 07-10-2018, 8:11 AM
I also live on the MD Eastern Shore and routinely listen to the Talbot system (site 6). Occasionally when I switch between listening to conventional vhf pager tones and the trimmed system I'll see it lock on to site 5, but this usually results in no audio unless there is a Talbot radio affiliated with that site causing the tgids that I'm interested in to be broadcast from there.
So most of the time the ability to program multiple sites works well enough, but you have to keep an eye on things.
Old 07-10-2018, 8:17 AM
troymail's Avatar
Not sure what that means -- turned off?
Also, if you manage to get at times switched to another site that doesn't carry your talkgroups 100% of the time (i.e. the Talbot simulcast), the way things work between the pager and the FiRST system, it sounds like you really want/need a zone/knob, etc. that is "fixed" on only the primary site for your county - at least as an option.
Unication G5(UHF)
Old 07-10-2018, 11:41 AM
mdsxfire's Avatar
I programmed a bunch of sites on the NJICS system for a road trip a few weeks ago and it did very well switch sites as I travelled along my route, Not sure if it went out of range before it switched to the next site, I do have the out of range alert setup but donít remember hearing it.
Overall I would say it did great!
Old 07-11-2018, 6:26 AM
rvacs's Avatar
Yes would love to do this myself have multiple Simulcast Sites in 1 site in PPS.
But I learned some talk groups aren't carried on some of the Simulcast Sites.
Old 07-11-2018, 8:52 AM
Just add the site then if its not and it will auto switch
Old 07-12-2018, 12:35 PM
Sometimes after it is on for a while, my G4 will go "silent" like it's lost the signal. When I power off then on, I immediately start receiving. Not sure why. Maybe system switching to a different control channel frequency?
Old 07-12-2018, 1:33 PM
dseven's Avatar
You can check what frequency it's on by scrolling down to page 5 on the main display.
Old 07-12-2018, 5:54 PM
Signal-Zero's Avatar
Iíve had no problem with my G5 switching sites on numerous systems while traveling up and down the east coast. SEGARRN, Palmetto, VIPER, MDFirst, NJICS, etc.
"We celebrate our independence from the Government, not our dependence on it."
Old 07-12-2018, 6:27 PM
davidzimmerman's Avatar
mine works GREAT on the Ohio Marcs while on the Ohio TurnPike
Old 07-13-2018, 9:48 AM
troymail's Avatar
I thought I recall seeing something like this quite some time ago under certain conditions that I cannot recall at this point. Other than which system(s) I was monitoring at the time, the only other thing that has really changed (for me) is the firmware versions....
As with most products where firmware changes, each version seems to have it's own "quirks". Having said that, since the Phase 2 upgrade of my G5 and subsequent release/installation of the latest firmware, I've seen almost no issues and the audio is great.
Is your unit Phase 2 running the latest f/w?
There's probably nothing wrong with it but I'd also be curious to take a look at your profile.
Unication G5(UHF)
Old 07-16-2018, 3:15 PM
Monitoring the TOPAZ RWS, Mesa/Gilbert, AZ Primarily Gilbert PD. Yes, Phase II as purchased from Ray's, firmware is V1.00-T08.
Old 07-17-2018, 1:06 PM
troymail's Avatar
Can you export and post a copy of your profile/programming?
Unication G5(UHF)
Old 07-17-2018, 10:39 PM
Hum, please forgive my ignorance. I have exported the profile but not sure how to attach it here, only certain file types allowed from what I can tell.
Old 07-18-2018, 10:35 AM
LEH's Avatar
LEH LEH is offline
Can you zip the file? The forum accepts them. There is a list of accepted file formats in the 'additional options' block of the comment page.
Lynn
Old 07-18-2018, 11:30 AM
Send it to ones email, in the exact form so its easier on the next party
