Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 08-04-2018, 4:09 PM
hjvan's Avatar
Default Suggestions?
Just ordered new G4 from Zip Scanners and it arrived yesterday. I've been able to set up programming a couple of my local p25 systems in KC area. The problem is have is that I receive an error message anytime I try to listen to one particular site (and its a big one, Kansas City site - which carries all KC PD traffic). Other sites on the same P25 system work ok, but this particular one gives me an error message stating I need to reset the unit. I'd double and triple checked that the site id info and control channel info is correct.
Any ideas or thoughts?
Thanks all
Old 08-04-2018, 4:37 PM
Unication Representative
Fixed In our latest firmware. There is data on that channel that is not following protocol. What firmware version is in your G4?
Old 08-04-2018, 6:13 PM
What is the latest firmware?
Old 08-04-2018, 8:37 PM
hjvan's Avatar
Firmware is showing V.100-T08
Old 08-05-2018, 12:19 PM
hjvan's Avatar
Is this the correct firmware version? If not, can someone point me to the most recent FW?
Thanks!
Old 08-05-2018, 3:52 PM
Mine has V1.10-T06
Old 08-05-2018, 4:46 PM
hjvan's Avatar
Originally Posted by Pezking View Post
Mine has V1.10-T06
Strange....I just had it shipped to me on Friday. Sounds like a need the latest firmware update. Do I contact Zip Scanners (where I purchased it from) for this? Or can someone point me to where I would locate latest firmware?
thanks so much
Old 08-06-2018, 11:02 AM
LEH's Avatar
LEH LEH is offline
Ray made a comment on the Facebook Unication page about this last week. The T06 is not the final version for the next release. Here is Ray's comment:
"the member that had his updated to a newer firmware (T06) is actually not the final release. Unication is testing T07..."
Ray and a couple of others have said the new firmware will be released after the APCO conference in Los Vegas this week. Another comment, forget where, was that Unication would be doing the upgrade in their booth for anyone with the pager with them.
So if you don't think you have the latest firmware, wait a bit and the new one will be released.
I should add, there is a link on the Unication web site to add your name to the email notification list for the firmware updates.
Lynn
Old 08-06-2018, 11:19 AM
The latest official firmware is V1.00-T08 That what shipped when the Phase 2 was released.
Old 08-06-2018, 2:29 PM
b1100mac's Avatar
The latest PPS software is on the unication usa website NOW and is VO.3.12.6
The soon to be released firmware will be V1.10 for all units including phase ll
Unication G5 UHF Phase ll times 5
Old 08-06-2018, 6:44 PM
Signal-Zero's Avatar
Ok and do you notice anything different in that PPS ? Like I mentioned, the only change I noticed in the last one was the increase to 64 zones from 32.
"We celebrate our independence from the Government, not our dependence on it."
Old 08-06-2018, 6:58 PM
b1100mac's Avatar
Unfortunately not being an Uber technical guy, mostly an end-user, when new software or PPS changes come out, I download them turn on the radio and if everything works fine I shut the laptop off and go on about my business. I donít spend a lot of time analyzing the software if any for that matter. So iím not much help. The zone issue has never come up for me as i only use 13....mac
Old 08-06-2018, 7:02 PM
LOL...hey, if it ainít broke donít fix it !
Iíll download and play around.
Old 08-07-2018, 7:01 AM
NC3Z's Avatar
My G4 has firmware V1.10-T07 from the factory. Did not find anything new.
Gary NC3Z
NC AHIMT COML
Old 08-07-2018, 12:32 PM
I saw DMR in the newest PPS but didn't look too close.
Sent from my SM-G965U using Tapatalk
Old 08-09-2018, 8:44 PM
I looked through PPS V0.3.12.6 and there is nothing for DMR ? Where did you happen to see this ?
Old 08-09-2018, 9:16 PM
BenScan's Avatar
PPS Tab 3, you have to add the protocol first. I messed around with it a little the other day, but wasn't able to test it, since my radios are not DMR capable yet.
I believe after adding the protocols for either or both time slots, you would then add the relevant frequencies in PPS Tab 2, and then link the frequency to the protocol in PPS Tab 5, and talkgroups would be added in PPS Tab 4.
That's as much as I know, and it may be totally wrong. I should add that after doing those steps and attempting to program my non-DMR G4/G5s, I wasn't able to, so I had to remove the above programming steps to be able to do any non-DMR programming.
Ben
Old 08-10-2018, 5:30 AM
When scrolling down the list of models and it says the supported protocols. I just happen to see DMR listed on a few of them.
Old 08-10-2018, 8:34 AM
Ok. That protocol is currently not an option in the programming menu...at least not yet. I believe they listed it previously in that same ďnoteĒ area.
Old 08-10-2018, 3:57 PM
Ah, thanks. I only saw it briefly and didn't actually try it out or see what model it matched up to.
