Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 10-01-2018, 9:13 PM
ffemt25's Avatar
Default Multiple 2 tone decoding
Is it possible to have multiple sets of 2 tone decoding happen on 1 talk group? I have several different stations I want my G5 to alert for off of 1 talk group but it says I can only have 1 talk group with the same TG ID assigned to any zone. Is it possible to add multiple 2 tone decodes to the same ID? Thanks in advance.
Old 10-01-2018, 9:17 PM
TFrank615's Avatar
For which freq band?
Tyler Franklin
Firefighter/EMT Ohio
Old 10-01-2018, 9:18 PM
ffemt25's Avatar
700/800 P25. I have it decoding 1 set of tones now.
Old 10-01-2018, 9:32 PM
TFrank615's Avatar
Do you know how to export your profile? If so do that and send it to my email. Easier for me to show them explain lol. Tyler-Franklin@outlook.com include what other tone pairs you want and a name for them
Tyler Franklin
Old 10-01-2018, 9:54 PM
ffemt25's Avatar
will do thank you
Old 10-02-2018, 3:27 PM
CFP387's Avatar
I have several tone pairs that are set to activate on a single talk group in my G5. I've found that when all the tones are set off only one pair will activate the unit. The others pass through with no activation unlike the Minitor pagers which would activate on every tone that was programmed.
BC75XLT, BC355N, BC898T, BCD436HP, BCD536HP, UNICATION G5(VHF), MOTOROLA XTS5000R
Old 10-03-2018, 1:48 PM
I知 guessing this is over P25, cause you mentioned talk group. I have had the same issue since QC over P25 came out. I have the same 2 tone pairs on a simul analog freq and all alert! If you find a fix let me know please.
Old 10-03-2018, 1:50 PM
TFrank615's Avatar
Shoot me an email with the unipps file and let me look at at, I helped this guy get his fixed up. I知 at work know but can look at it in a little while Tyler-Franklin@outlook.com
Tyler Franklin
Old 10-03-2018, 3:15 PM
Thanks, I will, but it may be a few days til i get it to you. I知 on vacation. Thanks for your help.
Old 10-03-2018, 3:17 PM
TFrank615's Avatar
No problem! Easier to show then explain for me lmao
Tyler Franklin
Old 10-03-2018, 9:36 PM
I have been having this same problemail on a Motorola vhf p25 p2 system. I've been back and fourth with unication and we still can't figure out the problem. The problem I strongly believe is the minimum tone gap in tab 3 of the programming. U can only have 500ms gap. When my county does multiple tones there's zero gap between tones. When you look at your programming for analog 2tone you see under tone 1 a zero gap and tone 2 a zero gap and all tones will activate. P25 is looking for that 500ms gap which doesn't happen with stacked tones. I've asked numerous times if tab 3 minium gap can be changed in the programming but don't seem to get any answers.
Old 10-03-2018, 11:00 PM
TFrank615's Avatar
Not too sure on the VHF side with these. The other two are/were having problems with 7/800 P25
Tyler Franklin
Old 10-07-2018, 12:33 PM
TFrank615's Avatar
Still needing help man?
Tyler Franklin
Old 10-07-2018, 5:44 PM
Yes, thanks, just got back from gatlinburg today. I値l email you tomorrow.
Old 10-07-2018, 5:46 PM
TFrank615's Avatar
Sounds good! Tyler-Franklin@outlook.com
Tyler Franklin
Old 10-21-2018, 7:02 PM
Just saw this thread and if I'm reading this correctly, I think what is being asked is if it is possible for the G5 to alert for sequential pages (more than a single one) on QCII over P25. If that is what is being asked, is that possible now? I didn't want to start a new thread if that is the same question. When I put my G5 into trunking TG-scan and have two-tone pages set up, it only alerts for the first one and then the squelch stays open for the remaining pages and dispatch.
Old 10-21-2018, 7:30 PM
TFrank615's Avatar
Unless anyone else has more info, which would be awesome btw, I do not know of a way to do that yet or if it is even possible
Tyler Franklin
Old 10-22-2018, 4:45 PM
At this point it doesn't seem possible on some systems. My Motorola vhf p2 system it only alerts one tone. When tones are being sent out there is no gap between the tones. If there's a half Second to a 1 second delay between tones then they will alert. I be leave it's something in the programming. You can only set it to a 500ms gap
Old 10-22-2018, 5:15 PM
TFrank615's Avatar
On our tones there痴 at least a good 2 second gap or more between two sets of tones
Tyler Franklin
Old 10-25-2018, 6:50 PM
Do you have the problem with multiple sets of 2 tone activating. Mine will only set of 1 tone
