Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Unication Forum
Unication Forum - Forum for discussion of Unication products.
Old 10-08-2018, 2:37 PM
Default Inside info
Does anyone have inside info as to why no scan hold yet? Just curious.
Matt
Old 10-08-2018, 4:38 PM
Its a public safety device targeting fire / ems users who use them as pagers or monitor one channel.
We are the side users who want what the pager was not meant for. At least not yet.
Hopefully Unication is looking at making us scanner users a targeted market.
Old 10-08-2018, 5:54 PM
Maybe because it's not a scanner.
Old 10-08-2018, 8:04 PM
W8RMH's Avatar
Wouldn't Fire Service users benefit from a scan hold as well?
Old 10-08-2018, 8:20 PM
Spitfire8520's Avatar
A vast majority of the users would have dedicated knob positions for individual channels much like an actual radio. This simplifies operation of the pager and doesn't require them to look at the screen and mess with buttons. Actual intended users would also likely be parked on their own dispatch and not scanning to minimize their chances of missing a call.
Mile-High Spitfire
ē RadioShack Pro-106 ē RadioShack Pro-652 ē RTL-SDR ē
MNN-250
Old 10-08-2018, 11:09 PM
I believe they would benefit for sure. I can't think of any radio with scanning capabilities that you can't stop the scanning, or hold. My Motorola radios all have scan which you can turn on and off. I'm sure it's the same with Harris, Relm, Kenwood, and Icom. They are all professional radios like the Unication.
Matt
Old 10-09-2018, 6:39 AM
It really depends how you program the radio, and whether you set up one tgid per knob position or multiple.
For our county there really is no need for a scan hold. Once the dispatch takes place we know which tgid is going to be used for tac communications.
Old 10-09-2018, 8:27 AM
krokus's Avatar
That is going to vary, but not for most FD users. Having priority scanning, and thoughtful selection of layout, your primary concern be the priority channel/TG.
Sent using Tapatalk
Old 10-09-2018, 5:34 PM
Homeboys-Scanna's Avatar
We've been asking for it for years, and they just won't do it.
"Copy, 132 and Bush, cover's code 3."
Old 10-09-2018, 8:00 PM
TFrank615's Avatar
In my Departments case, this may help us. We are dispatched on 2 talkgroups, however only one of those two talkgroups transmits tones, and the other is for unit to dispatch traffic. What screws some things up is even when dispatch is answering a unit, theyre still talking over both talkgroups and not just the unit to dispatch channel.
Tyler Franklin
Firefighter/EMT Ohio
Old 10-10-2018, 2:06 AM
krokus's Avatar
Then one of two things would solve this.
1) Dispatch only talks on the dispatch TG when making the initial alert. All other comms are one the answer TG.
2) After being alerted, change the selector knob to the next position, which puts the answer TG as priority.
Sent using Tapatalk
Old 10-10-2018, 2:09 AM
krokus's Avatar
Yet no one has given an answer to what other feature is to be sacrificed, to convert a button to being a hold. (Assuming it is possible, with a firmware change.)
Sent using Tapatalk
Old 10-10-2018, 7:25 AM
TFrank615's Avatar
Sent using Tapatalk
Thatís 100% to complicated for the midage and older guys to comprehend. Was trying to make it easier and all on one channel. Which Iíve figured out, itís not the 100% best but itís been working decently so far
Tyler Franklin
Old 10-10-2018, 11:20 AM
captaincab's Avatar
Location: monitoring delco pa with gre psr300 pro2053 and bearcat 560xlt
Idk all my fire department portables had a scan feature. And so did all my 2 channel Minitors. And our portables simply switched automatically to our dispatch channel if it detected our tones during scan.
