Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Advanced Technical Topics
Uniden Advanced Technical Topics For all threads regarding technical performance of specific models or general higher tier, technically oriented discussion of the technology used in Uniden scanners. Please use the Tech Support forum for all normal questions.
  #81 (permalink)
Old 01-25-2014, 1:05 PM
szron's Avatar
There you go. Simulcast performance on MPSCS.
New Uniden BCD536HP Simulcast Performance on MPSCS - YouTube
K7POL
Monitoring MPSCS
  #82 (permalink)
Old 01-25-2014, 1:59 PM
Stock antenna?
  #83 (permalink)
Old 01-25-2014, 3:28 PM
szron's Avatar
Yes, Inkster&Plymouth
Sent from my Nexus 4 using Tapatalk
K7POL
Monitoring MPSCS
  #84 (permalink)
Old 01-25-2014, 4:37 PM
Forts's Avatar
Mentor
Thanks very much for the MPSCS video. I listen to this system fairly often and the simulcast sites are brutal to try and listen to. Very encouraging!!
  #85 (permalink)
Old 01-26-2014, 2:22 PM
W9BU's Avatar
Lead Wiki Manager
Video of a BCD536HP in action on the Indianapolis/Marion County DPS 800 MHz P25 LSM CQPSK simulcast system.
Uniden BCD536HP scanning IDPSC (MECA) - YouTube
Lead Wiki Manager and Moderator for the Radio Reference Amateur Radio Forums.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- Joe Walsh WB6ACU
  #86 (permalink)
Old 01-26-2014, 2:52 PM
That was not very good at all the simulcast break up was bad at times from the cars and dispatch or is that good for that system?
  #87 (permalink)
Old 01-26-2014, 3:04 PM
You can see the "signal graph" going up and down with poor signal, seems the "stock antenna is what everyone is raving about??........
RoninJoliet
  #88 (permalink)
Old 01-26-2014, 3:13 PM
KevinC's Avatar
Moderator
I saw numerous of the dreaded "stops on a TG but no audio" instances.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
  #89 (permalink)
Old 01-26-2014, 3:31 PM
PiccoIntegra's Avatar
That is a terrible video of the performance. It exhibits the same signal behavior as the old radios. I made the same observations in the good videos too...
It's like they tweaked the squelch circuit to not rapidly open and close, so people don't have to completely open the squelch on their own. This is not a fix at all, they just don't get it.
  #90 (permalink)
Old 01-26-2014, 4:56 PM
KC0CSE's Avatar
I have better performance from my Pro 106 than this...no not a fix...this is terrible ......I'm not paying over $500 for the same problem...no thanks Uniden!!
  #91 (permalink)
Old 01-26-2014, 5:09 PM
wise871's Avatar
FL, GA, AL, MS Admin
Out of all the reviews so far the IPDSC system is the only one struggling so far. From the half dozen other reports the reviews have been the same or extremely positive. I wouldn't base my buying decision on this unless I live in that area. There are more reports to come as users get there radios. I like to see reports from Atlanta, Phoenix, etc. The IPDSC system may just be a total nightmare to monitor.
Dan M
BCD436HP /BCD536HP /BCD396XT /BCD996T(XT) /BCT15X /PRO-197 /PRO-106 /PSR-410 /HP-1 /BC898T
  #92 (permalink)
Old 01-26-2014, 5:17 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; LG-LS720 Build/JZO54K) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
What other radios have been used from this location and how have they perforned.
  #93 (permalink)
Old 01-26-2014, 5:21 PM
KC0CSE's Avatar
any simulcast system is a nightmare if you have to put up with it...so either you have fixed the problem or you have not...real simple....for $600 bucks..Uniden will not come out right and say they have....have they?
  #94 (permalink)
Old 01-26-2014, 5:35 PM
kycophpd's Avatar
I think Uniden has said they improved simulcast on several occasions. For me, it has completely. The MetroSafe system in Louisville has been a nightmare on my Pro-106 and Pro-197. When mobile, I was lucky to get half the transmissions on either device. On the 106 I had a 800mhz antenna. On the 197, I had a decent antenna I bought from a local radio shop that was designed for 800mhz.
On my drive back from the Ham Station in Indiana, I stopped and did a quick power on of the BCD536HP and using the stock antenna, I set it to scan just MetroSafe. From the Indiana line thru the western part of Louisville then from north Louisville to south Louisville, I did not have the first garbled transmission. The audio was also much clearer and sounded just like it was coming from one of the portables the officers carry.
I am very impressed.
I believe performance will vary by system and also user setup but for the vast majority posting, it has been a great improvement.
  #95 (permalink)
Old 01-26-2014, 5:46 PM
nategb's Avatar
From YouTube description:
"The scanner at this point was right out of the box with no adjustments to the settings."
Does that mean no firmware update was performed?
Uniden BCD436HP w/RS 800 antenna
  #96 (permalink)
Old 01-26-2014, 6:02 PM
kycophpd's Avatar
Yes thay could be part of the problem because UPMan said they made several fixes from the firmware that was sent for production. Also, I would be interested to see this same system monitored with the stock antenna.
  #97 (permalink)
Old 01-26-2014, 6:04 PM
KC0CSE's Avatar
I'm glad your satisfied with this unit...and the money you spent on it...I hope to see more reports that are positive in nature...I will still wait and get the full review ...thank you
  #98 (permalink)
Old 01-26-2014, 6:05 PM
You are correct... Uniden has never stated that they have corrected, solved, enhanced simulcast permronace in any way.
UPMan specifically stated he would not comment on it and that users would have to decide for themselves.
My point is the same as yours... if Uniden HAD made improvements to simulcast reception, they would have made it a huge selling point. But they have not.
So the only conclusion I can come to, is that they "maybe" made some small tweaks that helped a little, but not enough for them to be confident enough to declare any of these possible enhancements any sort of fix.
  #99 (permalink)
Old 01-26-2014, 6:08 PM
kycophpd's Avatar
Talking
A correction, I am never happy spending money! But I am completely satisfied with the purchase
  #100 (permalink)
Old 01-26-2014, 6:09 PM
KC0CSE's Avatar
My point is the same as your... if Uniden HAD made improvements to simulcast reception, they would have made it a huge selling point. But they have not.
thank you....I'm not crazy..
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
