This is in reqard to P25 ANALYZE functionality. Forgive me if I repeat someone else's wish. And I apologize if what I'm suggesting is way off base.
It seems the AUTO mode is working for some and not others. Some say the auto adjustments are so aggressive that it causes audio quality to go from good to bad (and perhaps back again). Some have suggested allowing the user to have some input, such as setting a smaller range of adjustment (ie 3 - 5 or 6 - 9) instead of having the radio test from 0 - 9 every time. And I think we need a simple quick way to save the settings, once we identify them.
So I guess what I am requesting is a SMART AUTO mode. Here's how I'd like to see it work:
I apply the new firmware and go into SMART AUTO ANALYZE for the first time. I HOLD on a channel. I say ANALYZE. The ALERT light is RED. As the radio performs it's adjustments, as the error rates improve the ALERT light begins to go to YELLOW and when the alert light gets to GREEN, I hit a button and the radio changes it's settings (saves them) and sets the mode to MANUAL for that channel. If I ever go into analyze mode for that channel again, I'll see the alert light is green (because it's been set to MANUAL) and know that the radio has already been set for that channel.
Perhaps part of its adjustment could also be to test both FM and NFM modulation settings.
I am not saying it's impossible but it seems that getting clean P25 audio adjustments, on-the-fly, automatically, may simply not be realistic. (Though GRE users seem to be very happy) That's not a slam against Uniden. They're certainly working on it. But until such time as they nail it, perhaps the user can help if Uniden gives us a method to do so.
Once I find a good P25 setting for a system, dept, or channel, I'd like to know that I'm done with it and not have the radio try to re-adjust it every time, causing me to lose the audio stability that I may have already saved.
As a former programmer, I know that if all the data and parameters are present, anything can be accomplished.
