Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Bug Reports
Uniden Bug Reports Use this forum for serious discussion of possible or known bugs (e.g., design flaws) or critical issues specific to certain models. Please use the Uniden Tavern forum for rants about deficiencies or flaws in hardware.
Old 01-18-2014, 4:46 PM
Default BCD536HP discovery mode bug (same as HP1)
The BCD536HP has the same bug I already reported to Paul in the HP1 with Discovery mode. The search hangs up forever on a P25 control channel with the Avoid button disabled so you can't move past it. This is demonstrated with the 407.8375 MHz P25 control channel in Houston. Discovery mode is useless if it includes the P25 control channel in the search range. I'm curious if anyone else has experienced this issue or if there is some oddity of the control channel in Houston.
Old 01-18-2014, 4:58 PM
KevinC's Avatar
Moderator
You'd think Beta testing would have caught that.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
Old 01-18-2014, 5:03 PM
DaveIN's Avatar
You having the same Discovery issue as Eric, Kevin?
Pop' Comm Monitoring Station ID: KPC9DV
CRB Research Monitor Station Registry: KIN9GP
GMRS: WQKL769
MARC ID:3126326
Old 01-18-2014, 5:05 PM
KevinC's Avatar
Moderator
I don't have a BCD536HP, but my HP-1 exhibits this issue.
BC-210XLT
Old 01-18-2014, 5:09 PM
MikeOxlong's Avatar
Global DB Admin/Senior Mod
Confirmed on a VHF P25 control channel with an HP-1. Search stops and the Avoid button doesn't work.
Mike.
Old 01-18-2014, 6:27 PM
Thumbs down
Originally Posted by kevinc View Post
you'd think beta testing would have caught that.
and why has this not been fixed all ready for the HP-1??
Old 01-18-2014, 7:08 PM
Yes, I have experienced this as well with a Motorola Type II SmartZone Omnilink System (Commonwealth Edison/Exelon (Northern IL) on a HomePatrol here in Grundy County, IL. I started a thread about a year ago on this issue with no good result. I was intermittently able to get past the freq by turning my attenuator on but that didn't do the trick 100% of the time.
It is a very aggravating problem.
BCD536HP / PSR-800 / Pro 97 / Pro 2066 / Pro 50
Old 01-19-2014, 1:12 AM
WayneH's Avatar
Moderator
I just noticed this also when I tried out this feature with the 536. This isn't exactly a trivial, or even minor, bug. It basically kills the feature in the radio.
-Wayne
PM's are permitted by contact list only. Please use direct email: wayne_h at radioreference dot com
Please follow the forum rules and contact a moderator directly, not via a thread.
Old 01-19-2014, 6:44 AM
Same here on HP-1.
Old 01-19-2014, 7:24 AM
NWI_Scanner_Guy's Avatar
Default question
As I'm considering adding the extreme features to my HP-1, this is good information to know about.
I'm assuming you have to turn the scanner off and then back on, and then restart the search to "solve" the problem?
HP1-E / BCD-536HP / BCD-996XT / BCT-15X / PRO-197
PSR-800 / BCD-436HP / BCD-396XT / BR-330T / BC-246T
FT-7900R / TH-9800 / TH-9000 (220mhz) / DR-235T (220mhz) / KG-UV8D x2 / UV-82X / UV-3R
Old 01-19-2014, 8:12 AM
Dafe1er's Avatar
Thumbs down
Because they "moved on" to bigger and better things So, why would they need to do anything for us HP-1 owners?
This has been happening for TWO years with my HP. Every time I do a discovery it does it. Even in conventional mode it will hang on a frequency and NOT let you select avoid.
I have however found that walking around moving the scanner around in the air WITH antenna connected you can get the hung up channel to "Squelch" and quickly select the avoid button while active to avoid it.
I am just a Novice, compared to some here. I am willing to learn and once know what has been taught to me, will help others know this awesome hobby of ours.
Old 01-20-2014, 5:36 PM
KevinC's Avatar
Moderator
Forgot to ask, I assume you are using the most current FW?
BC-210XLT
Old 01-20-2014, 5:48 PM
MikeOxlong's Avatar
Latest and greatest for me.
Mike.
Old 01-21-2014, 2:24 PM
Paul, any input on this? is this at least being worked on? if so, will the hp1 get the fix, or only the new scanners?
Uniden BCD396XT, BCD396T, BC125AT, BC700A, Radio Shack Pro-83, Motorola HT1000, 4 Motorola JT1000s
Old 01-21-2014, 6:37 PM
Thumbs down
Good LUCK!!!! Every time any questions arise that pertain to the HP1 Paul is nowhere to be found.
UPMAn your lack of acknowledgement of a firmware issue that's been reported here in many forums and on yahoo and twitter.
Paul i'm sure you have read this thread???? You have posted on other threads sense this thread was started.
Don't get me wrong, I like my HP1 and Uniden BUT, I really want to pull the trigger on a new 536 and would like to purchase a Extreme Upgrade for my HP1 TODAY but I will not until this gets address.
Old 01-22-2014, 9:41 AM
N1SQB's Avatar
This is not good! Apparently they not only brought over HP1 features into the new models, but bugs as well. This makes me reluctant to invest in new equipment right now. Even at $499.99 for a 436HP, that is still a huge chuck of change for most folks. I hope Uniden addresses this issue soon.
Manny
N1SQB-AMATEUR EXTRA
The difference between men and boys, is the price they pay for toys!
Old 01-22-2014, 10:51 AM
i agree. id have more respect for the company if they at least acknowledged the problem and admitted they dont have a fix for it yet, instead of outright ignoring the issue.
Old 01-22-2014, 1:15 PM
safetyobc's Avatar
Forums Moderator
While I do agree that bugs are annoying I won't go so far to say I won't buy something because it doesn't work 100% perfectly. By that logic, who among you would own any electronic? Computers, iPads, Android tablets, smartphones, etc, etc, etc. Even if this bug exists, I will still buy them. I rarely use the scanners to search a range of frequencies and even more rare is P25 conventional channels in my area. I now some have several and want to find them and can see where this may be an issue. To each his own.
Old 01-22-2014, 1:55 PM
N1SQB's Avatar
The difference is that when I buy these things you mentioned, I don't buy them already knowing there is a problem that the manufacturer is aware of and has yet to address! Imagine if a car dealer says to you " this car is brand new, it has a XXXX problem, the factory has known about it, hasnt addressed it, not sure if they're going to address it, but please, buy the car anyway." This is the problem that exists right now. Without knowing what OTHER new issues will come up once these production units get in the field, they are already starting out with one they do know about and have yet to address. When Uniden decided to come out with models that include features from a previous model, the first thing they should have done is look at the bugs or issues with the current model ( HP1) and make sure they do not transfer over to the new models BEFORE they are fixed. It's just that simple.
Manny
N1SQB-AMATEUR EXTRA
Old 01-22-2014, 5:45 PM
Thumbs down
DING DING!!!!!!!!!!! WINNER!!!!!!!!!!!
And Paul is still posting today.......Just not in this thread!!!!! =(
