Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Bug Reports
Uniden Bug Reports Use this forum for serious discussion of possible or known bugs (e.g., design flaws) or critical issues specific to certain models. Please use the Uniden Tavern forum for rants about deficiencies or flaws in hardware.
Old 03-19-2014, 4:31 PM
Default Uniden 436/536HP clock problems
Every Time I turn on either unit I end up having to re-program the clock and day/month etc.
Any Help would be appreciated.
Old 03-19-2014, 4:33 PM
Did you leave it plugged in for more than 24 hours?
Old 03-19-2014, 4:36 PM
the 536 is always plugged in..
Old 03-19-2014, 4:42 PM
UPMan's Avatar
Uniden Representative
And turned on.
Uniden Product Ninja
Professional Scanner Developer
Old 03-19-2014, 4:45 PM
No I usually turn them on and off. But there lies the problem..
Old 03-20-2014, 6:20 PM
Administrator
This seems to be related:
Time resets when powered scanner is off for long periods
To contact me please use the forum email function as I do not accept Private Messages unless you're on my contact list.
All rules and guidelines are covered in this forum. These are required reading for new members and all existing should follow for any updates.
Old 03-27-2014, 6:39 AM
I am having the clock reset problem with the BCD436HP. Virtually every time I turn on the radio, I need to reset the date/time. I have upgraded to the latest firmware. Any suggestions?
Old 03-27-2014, 8:03 AM
Dafe1er's Avatar
Since the first time of setting the clock until now I have had no issues with it needing to be redone.
I switch out batteries twice a day and never once plugged the scanner in to charge off the PC.
Maybe that is why? I switch batteries.
I am just a Novice, compared to some here. I am willing to learn and once know what has been taught to me, will help others know this awesome hobby of ours.
Old 03-27-2014, 8:22 AM
Donald Roberts's Avatar
Originally Posted by marcov View Post
i am having the clock reset problem with the bcd436hp. Virtually every time i turn on the radio, i need to reset the date/time. I have upgraded to the latest firmware. Any suggestions?
has the internal battery had time to charge over night?
Old 03-27-2014, 8:30 AM
Default Clock
you must have a defective unit both my clocks are dead on all the time. No pun intended. Never had to reset either of them.
Old 03-27-2014, 10:43 AM
harryshute's Avatar
I've had this issue on all three of my 436's. What has finally helped me was when I plugged in the USB I selected No when asked about charging. This apparently allows the internal battery to charge rather than the AA batteries. I have used the set clock function in settings rather than on the power up screen. Rather than charging over night it's more like 50 hours with this unit.
Scanning since before scanners
Old 03-27-2014, 12:18 PM
rad1oreference's Avatar
I had the same issue when I first powered the unit. It happened 3-4 times but since then, it never asked me for the time etc.
I also plug in the USB and say no to charge.
Old 03-27-2014, 12:24 PM
best practices with portable scanner units is to say no to charging and use an external battery charger to properly charge the batteries. I just don't want any damage to my batteries or overheat them and leak acid into my radio. Not saying it will ever happen but I just don't want to take the chance. Plus then I can cycle my batteries in the charger to get full use of them.
Old 04-02-2014, 11:40 PM
Unhappy
How are you guys getting the 436HP to operate from the USB cable?
Mine won't do it and I can't find it in either the Uniden manual or
the Easy to Read version. Both are seriously lacking when it
comes to battery uses and recharging.
When my 436HP is OFF and the USB cable is connected to the PC
I see a Normal Charging message. If I power the scanner ON then it
says USB Cable Detected and it wants me to choose what type of
connection by pressing either Yes or No.
If the scanner was already ON when I plug in the USB cable I get
exactly the same result.
So, what nobs do I twiddle or buttons do I push in order to run the
436HP from the USB power supply?
teknishun KF5OPQ
Old 04-02-2014, 11:48 PM
Question Re: 436HP clock issue and my previous message
teknishun KF5OPQ
I forgot to mention I am having the same problem with the 436HP clock
having to be reset if the scanner stays turned off and not connecetd
to the USB for several days. I am using 2300 mAh batteries and I just
don't believe the clock alone would drain the batteries that quickly.
teknishun KF5OPQ
Old 04-03-2014, 11:22 AM
UPMan's Avatar
1) Select serial mode for the USB.
2) Leave the scanner turned on w/power for a long time to charge the internal battery (they clock does not run off of the AA's).
Old 04-03-2014, 11:30 AM
How much current does the 436 draw when operating? I couldn't find it in the manual's specification pages.
Old 04-03-2014, 12:07 PM
Mine draws 0.02 amp at 120 volts.
I don't have a way to measure the current at 5 volts.
Old 04-03-2014, 12:42 PM
USB 1.0 spec max is 500 ma, My guess is the radio uses less than that.
Old 04-03-2014, 1:21 PM
krokus's Avatar
Default Re: Uniden 436/536HP clock problems
Would there be a way to turn off the internal charger for the AA batteries? That way the internal battery can charge, without applying a charge to the removable batteries.
Sent via Tapatalk
