Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums
Uniden Forums - Forums for the discussion of all Uniden scanning radios and receivers. The main forum is reserved for Official Uniden Announcements. Please choose a sub-forum for any other posts.
Please scroll down to the bottom of this page to review the sticky threads which cover the most common questions and answers regarding Uniden scanner products.
Closed Thread
  #81 (permalink)
Old 03-01-2014, 6:12 PM
W9BU's Avatar
Lead Wiki Manager
Originally Posted by wise871 View Post
You right and there is something different with the firmware but no details were released.
Have you read the release notes posted in the Uniden Twiki?
It clearly states:
Fixed an issue where starting of some vehicles caused the scanner's audio to stop working.
It appears that Uniden fixed the problem by forcing the scanner to reboot if the supply voltage drops below a set level. As others have stated, the supply voltage to your scanner may be dropping below the threshold allowed by the new firmware. As a result, your scanner is rebooting when you start the vehicle. How you solve the voltage drop problem is outside the scope of this thread.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
  #82 (permalink)
Old 03-01-2014, 6:24 PM
I don't know why I would need to revisit my installation when it worked perfectly before the firmware update. You right and there is something different with the firmware but no details were released.
Here is the deal, maybe Uniden needs to put a user configurable option in the firmware/software that can "switch" on or off the low Voltage detect issue??
I have no specific details on what Uniden did to resolve the issue where the scanner would loose audio on some engine/vehicle starts if the scanner was still on.
Just because the scanner would not have an issue with the original firmware and now has an issue with the newer firmware, this does not mean you may need to revisit your installation/DC Voltage supply.
You may need to put a diodes and a small SLA battery to "float" the scanner.
The newer models of scanners have a LOT more software and logic and they appear to be more sensitive to low Voltage drop outs.
After hearing all of this, I will be inclined to put a small "float" battery and isolation in even for my 996XT and remote head installation.
  #83 (permalink)
Old 03-01-2014, 6:34 PM
Post 536HP and the little things that really do matter in the end
There was other changes that are very Minor but fixed or look better or work better on the 536. For instance the Volume you could turn it slowly 5 or 6 Clicks even more before it would even Reolize you was turning the knob. Same thing with the Squelch.. You could turn that thing all day long at times and NO Response. I have turned it all the way to Zero and leave it.. and it will never break the squelch until it hears something and then OH the squelch is zero and hen start making all kinds of racket.. it's as if the scanner is so busy that it doesn't know what it's left hand is doing unless you tug on it's thumb. It Acts Absent Minded about the little things they over looked in the Details.
  #84 (permalink)
Old 03-01-2014, 6:45 PM
signal500's Avatar
Default BCD536HP First Maintenance Release v1.03.03 Available
My voltage remains steady and I have a new battery. As I stated before I've been running the 536 for almost a month now and this is a first since the update. My neighbor Signal 500 is also seeing the same thing. No explanation was given on the update on how it handles vehicle start ups.
Dan, it seems that the newest firmware has a "low voltage detect" option. If the voltage dips below a certain threshold, it will restart the scanner. I'm sure this is Unidens workaround for the "no audio when starting a vehicle" issue. Even though we did not have that issue on our installs, it seems others did and the newest firmware made this change.
In order to keep the scanner from restarting every time we start our vehicle, we will need to install a 12 volt voltage stabilizer on the power lead of the scanner.
Douglas - K4DPS / WPUT291
My YouTube channel: http://www.youtube.com/user/k4dps
  #85 (permalink)
Old 03-01-2014, 6:55 PM
wise871's Avatar
Just great . Now I need to buy a part I didn't need before hand.
James - I was just going by your original message were you said the following "You might need to revisit you installation and/or get with Uniden to find out what the firmware fix was."
W9BU - I saw the release notes on the firmware update but it does not state that your scanner will reboot on you. It through me when the display just blacked out. If the release notes had said this is what would happen then I wouldn't have posted the original question in the notes. Something like "ATTN: If you voltage drops below a certain level your scanner will reboot to prevent damage during startup."
Thanks everyone. Off to find a 12 volt voltage stabilizer
  #86 (permalink)
Old 03-01-2014, 7:04 PM
signal500's Avatar
I would agree. Here is the link to one voltage stabilizer:
Newmar DC to DC Power Stabilizer
  #87 (permalink)
Old 03-01-2014, 7:18 PM
AC2OY's Avatar
After the firmware update scanner does sound better audio wise. I never noticed any long squelch tail or anything. It actually stopped of a Air Force frequency!!!
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Uniden 536 HP Kenwood TS-2000 Comet 250-B Diamond D3000N
  #88 (permalink)
Old 03-01-2014, 7:20 PM
wise871's Avatar
Thanks as always Doug but thats a lot of $$$ just to operate one scanner that worked before. I guess I'll just live with it. No more running into convince stores for coffee and leaving my scanner on.
Dan
Uniden:BCD436HP,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
  #89 (permalink)
Old 03-01-2014, 7:36 PM
A $15 SLA battery and a few diodes that will carry the current the scanner draws, about $30 or less it parts.
No need for an expensive DC Voltage stabilizer.
In some very special applications, I can see spending the money on an expensive DC power stabilizer, but for the hobbyist, the SLA/Diodes for under $30 should do the trick.
  #90 (permalink)
Old 03-01-2014, 8:05 PM
signal500's Avatar
Don't worry Dan, I'm taking JamesO advice and will build us something that will fix the restart/reboot.
  #91 (permalink)
Old 03-01-2014, 8:23 PM
wise871's Avatar
Sounds good Doug. Keep me updated. Got to have my coffee in the morning when I head to work.
Dan
  #92 (permalink)
Old 03-01-2014, 8:25 PM
Kingmobileaudio's Avatar
Should have it installed so that the Acc wire is the trigger.
This is how I have my install done. When I go to start my truck, it kills power to all my toys.. so it don't put more stress on my battery when trying to start..
Also look at this way. Some things can get damaged when the voltage drops to lower, and the best part about this when I turn my truck off it kills all my toy's so they ain't drawing any power to kill the battery.
  #93 (permalink)
Old 03-01-2014, 8:55 PM
Here's something from the manual on page 10:
"If the scanner loses power (as when you turn off your car’s ignition with the scanners power switch on), it can corrupt the microSD card. To ensure that does not happen, turn off the scanner before turning the car’s ignition off."
  #94 (permalink)
Old 03-01-2014, 8:58 PM
Arrow SMART AND PROPER
There ya go!.... you got the idea.....
  #95 (permalink)
Old 03-02-2014, 8:58 AM
nr2d's Avatar
Originally Posted by ofd8001 View Post
The TWIKI says, among other things, "Fixed an issue where the USB serial mode would stop working in some conditions."
I hope I'm not jinxing myself, but in the past hour or so of scanning while in "Serial Port", I've not seen the dreaded change from "Serial Port" to "Mass Storage". Still keeping my fingers crossed.
Happened to me 3 times Friday after the update and twice yesterday. No set pattern. Last night it happened only after about 2 minutes then again after about 1 hour.
  #96 (permalink)
Old 03-02-2014, 9:16 AM
How many Firmware fix's did it take with the other BCD'S? Just curious.
  #97 (permalink)
Old 03-02-2014, 9:47 AM
I have no equipment in any vehicle that don't suffer from voltage drop during the starter running.. I don't see a problem personally.
K7MHI
  #98 (permalink)
Old 03-02-2014, 9:54 AM
troymail's Avatar
Great. Something that worked fine before a firmware upgrade that required now yet another "workaround" to be fabricated. Fabulous.
I'm glad this doesn't happen when I buy my TV or car.
Unication G5(UHF)
  #99 (permalink)
Old 03-02-2014, 10:11 AM
troymail's Avatar
The problem is that for some of us - it worked fine before the FW fix and now it doesn't.
It's simply an another example of what works for some doesn't work for others.
Unication G5(UHF)
  #100 (permalink)
Old 03-02-2014, 10:49 PM
If I am happy with scanners current performance should I wait to update firmware?
Sent from my SCH-I545 using Tapatalk
Closed Thread
