K4EET
Chaplain
When programming the scanner, I noticed that multiple selections in a column are possible; e.g. <Shift> to select a continuous range or <Ctrl> to select discontinuous items. It would be "nice" if then you could change the selected items to the same parameter; e.g. from 2 second hold time to 4 second hold time with a single click. As it works now, even with multiple line-items selected, only the last item is actually changed to the new value.
This feature would save a lot of programming time...
Thanks for your consideration and a GREAT scanner!
73, Dave K4EET
_____________________
Retired E911 Police Communications Systems Manager
BC800XLT (1978) and BCD536HP (2015)
NOTE: I had a Motorola Police HT when 800 MHz Trunking
came about so did not need a scanner. LOL! :lol:
73, Dave K4EET
