Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 11-22-2008, 5:28 PM
Default Firmware Update BC996T
Problem: am having problems upgrading the firmware in my BCD996T.
Current firmware: v1.03.11
I have used the BCD996T_USAD program to backup my scanner settings and confirm PC to scanner communications are OK - COM1 at 115200. I also use the Proscan program to communicate with the scanner and it works file.
Problem: BC_VUP (firmware update) program doesn't "see" (read: communicate with scanner) and so wont update firmware. I have tried different versions of the BC_VUP program. They don't work. I have tried 2 different laptops to the scanner (in addition to the original PC) and the BC_VUP program just doesn't see the scanner even after the (press 6 & L/O keys) to put the scanner in (remote program?) mode so scanner is ready to accept firmware update.
I have read the followed upgrade directions to the letter several times. I have reset my scanner to factory defaults (after my backup) and still the BC_VUP program fails when trying to see the scanner.
Q.) Anyone know a trick to get the scanner into (remote program mode) so that the BC_VUP program will inject the BCD996T_V1_04_12.scn firmware into the scanner? I'm trying to get to the release 3 and I know I have to do all the in between steps to get there...
Old 11-22-2008, 6:19 PM
You don't just press L/O 6, you do it as you are powering on. The scanners display will light up but be blank.
Old 11-22-2008, 7:29 PM
Default Firmware Update BCD996T
Thanks RDale.
I've tried that (L/O & 6) using both the on/off switch and power plug in the back.
At all times the display screen changed to a blank "green" screen...then update failed...
Strange.
Old 11-22-2008, 9:43 PM
Viper43's Avatar
Are you using the front serial port, the back won't work for upgrades
V
Old 11-22-2008, 10:35 PM
Default the Front?
Viper43 - R U kidding?
I saw nothing in the instructions that stated that you have to use the front (serial port) for the upgrades...
Nothing. I can try that tomorrow.
R U serious?
Old 11-23-2008, 2:12 PM
Viper43 !
That was it!!!!
I had no clue you HAD TO USE the front port on the BCD996T.
I've been using the back (DB-9) for a few years to do "everything" monitor - Proscan - Butel...
aways worked fine.
Uniden download didn't say a thing about "you have to use" the front port of the scanner for the firmware update...
After I used that front port...upgrade worked just fine....
Thanks again!
Old 11-23-2008, 3:00 PM
Viper43's Avatar
Nope, I wasn't kidding Glad you got it working!
V
Originally Posted by TAnderson View Post
Viper43 !
That was it!!!!
aways worked fine.
Thanks again!
Old 11-23-2008, 3:07 PM
Wiki Admin Emeritus
These are the sort of little tips that I've been trying to accumulate in a wiki article so it doesn't have to be repeated time and again.
http://wiki.radioreference.com/index...anner_Firmware
If anyone has any more tips, particularly with the upcoming 15/246 firmware updates, please post them
73 Mike
Old 03-04-2014, 9:08 PM
MJC MJC is offline
My bcd996t works fine via serial port with my older desktop computer. However after buying the USB-1 cable for use with Win 7 laptop, scanner does not communicate at all. Using the ARC 996 pro software.
The link above isnt valid.
Any and all help would be appreciated, as I've heard others having this issue
Marty
Old 03-04-2014, 9:12 PM
Marty
Connecting scanners via USB - The RadioReference Wiki
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
