Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
  #81 (permalink)
Old 03-03-2014, 5:07 PM
Ghstwolf62's Avatar
Bearcat Warehouse currently has the Uniden complete cable for $84.90 and the Garmin WITH adapter for 89.85.
I just ordered the Uniden one on Saturday to go with the 436 I bought from them.
KJ4KFW
One of the few in the world apparently with radios & scanners that actually work like they're supposed to.
  #82 (permalink)
Old 03-03-2014, 5:11 PM
Has anyone had both the Uniden and Garmin and give feedback on both?
Sent from my SCH-I545 using Tapatalk
  #83 (permalink)
Old 03-03-2014, 5:32 PM
I may be wrong, but I believe the Uniden is a repackaged Garmin - if not, someone please yell.
Hp2(e),HP-1(e)x2, BC780, BCD996xt ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
  #84 (permalink)
Old 07-01-2014, 7:47 AM
Does anyone know if the Garmin nuvi 255W is compatible with the BCD436HP? Thanks Doug
Doug
  #85 (permalink)
Old 07-01-2014, 8:36 AM
UPMan's Avatar
Uniden Representative
My understanding is that it might be able to be used by connecting it to https://www.argentdata.com/catalog/p...roducts_id=114. That specific model is not listed, but perhaps you could email them and ask.
Uniden Product Ninja
Professional Scanner Developer
  #86 (permalink)
Old 07-06-2014, 1:00 AM
captaincraig44's Avatar
Any thoughts on whether this will work? I've got a Garmin eTrex Vista HCx that has a mini USB out. I'm hoping to simply take a USB cable, use a gender changer and plug in a USB cable with the 396XT connector on the end of it from eBay.
Craig Mills
Denver, CO
MNN //113//
  #87 (permalink)
Old 07-06-2014, 2:17 AM
dkf435's Avatar
NO, wrong protocol USB is a one way interface, must have a computer with USB port to connect, get a GPS with the old 4 pin Garmin round or blade connector.
David Kb7uns
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25 R10,20,71,72,75,7000,7100,8500, PC/R1000,2500, PSR500,600,800,PRO18,668,2035,96,106,197,BC760,796 ,996T,996XT,396T,396XT,HP1,HP1E,436HP,536HP
  #88 (permalink)
Old 07-06-2014, 5:08 AM
Is there any gps that will work that is simply plug and play?
Doug
  #89 (permalink)
Old 07-06-2014, 6:15 AM
AC0RV's Avatar
You need the Serial cable that comes with the 396xt or you may by be able to get it from scannermaster, a null modem adapter and a gender changer also available from scannermaster.
to conntect with the garmin etrex' serial cable.
At least that's what I need.
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
  #90 (permalink)
Old 07-06-2014, 6:21 AM
Dewey's Avatar
The bottom line is that you're looking for a GPS with serial output, and outputs standard NMEA commands. In the eTrex line, that would be the plain (basic) eTrex or the newer eTrex H. I use mine with an eTrex H sometimes.
  #91 (permalink)
Old 07-06-2014, 8:25 AM
This seems like a royal pain in the arse. Kind of defeats the purpose of having a portable handheld radio if you have to carry two or more additional cables and some adapters around. Holding out hope that an on-board GPS might be in the works in five years or so when the next round of radios (hopefully) comes out.
Sent from my Nexus 5 using Tapatalk
Craig Mills
Denver, CO
MNN //113//
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
