Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 03-17-2014, 12:03 PM
Default BCDx36HP not scanning a system
Anyone else have this issue? The system is sent to the scanner via sentinel and shows up in the list but the scanner does not scan the system. Only after changing the SQK and then changing it back to the original SQK does the system finally scan. Occurred on both the 536 and 436.
Old 03-17-2014, 12:17 PM
harryshute's Avatar
Yes I do have that issue on both the 536 and 436. I'll try your fix when I get back home. Sounds promising.
Scanning since before scanners
Old 03-18-2014, 5:48 PM
Same thing with me guys, still having issues. See it in Scanner List, but no scan...
Old 03-19-2014, 9:46 AM
Harry, did changing the SQK and then changing it back work for you too?
Old 03-19-2014, 10:38 AM
Did you check the box "erase favorites" when you copied from Sentinel to the scanner?
I have gotten some strange combinations of old and new FLs when I did not do this.
I assume you checked the normal things like:
Avoids checked
In your Profile have both "Monitor & Download" ON
Have all the appropriate "Service Types" ON
Old 03-19-2014, 11:30 AM
harryshute's Avatar
Blackhawk the change of the quick key number did not work for me. The tip about erasing favorites was a good one as I wasn't doing that. I'm now close to getting it working as I had planned.
Old 03-19-2014, 11:42 AM
Yes it happened to me twice on two systems. First I reset the scanner and re-uploaded everything and that did not fix it. I finally found another QK assigned (how, I have no idea) buried somewhere and changed it to none. Then it worked. When the second problem happened, I looked for that hidden QK found it and changed it to none, and everything was fine that time also. Have no idea how it got that way.
Old 03-19-2014, 5:03 PM
Ghstwolf62's Avatar
As stupid as I feel this is something else to consider.
The other night I spent a couple of hours pulling out what little hair I have left and generally going crazy trying to figure out why the thing wouldn't scan some updated things I had put in it.
Every time I thought I had it figured out it still wouldn't work.
Then I remembered something I'd seen and went and looked, sure enough I'd forgotten basics 101 on the thing.
The stuff I added did not have the QKs enabled in the per channel/dept options settings. No QKs means no scanning.
Once I enabled them it worked perfectly.
Don't know but thought it might help some.
KJ4KFW
One of the few in the world apparently with radios & scanners that actually work like they're supposed to.
Old 03-19-2014, 6:12 PM
All the QKs were enabled. Sent to scanner with a different software and I don't have the problem anymore.
Old 03-19-2014, 6:46 PM
Jay911's Avatar
This is the issue in these situations. You may think you have it enabled, but that's not necessarily the case. For some reason, either the scanner or Sentinel is "shutting off" quick keys that are not in use, either when you power up the scanner, or when it is read into Sentinel from the SD card. Either way, you have quick keys that are disabled, and you don't know it; when you put something in a "new" quick key, it remains disabled, even though you can see it in the scanner. This happened to me twice before I got it sorted out. Now, every time I write to the scanner, I triple-check that my desired quick keys are enabled.
I know you guys above are saying this isn't true, that you had them enabled, but read the radio into Sentinel, then go check which quick keys are enabled. I think you'll be surprised.
Old 03-20-2014, 5:06 PM
Ghstwolf62's Avatar
Thanks Jay. I wish I could claim scanner problem but for me it was all my fault. I had the QKs for what I had in there enabled and all the rest disabled. When I added more stuff I forgot all about that which caused my headache. Once I thought to check them I saw I hadn't enabled the previously off keys and once I did so my headache disappeared.
Believe me I thought I'd finally found one of these "Issues" that were being talked about. LOL
Turned out the "Issue" was me.
KJ4KFW
Old 03-20-2014, 5:33 PM
Jay911's Avatar
As much as I don't like insinuating that people have screwed up, it's the case in a lot of these situations. If you'll allow me to toot my own horn, even I have been caught off guard and confused by some of the settings in these new radios, and I've been messing around with scanners since the very early days. Everyone makes mistakes, and I'm not out to belittle anyone or point out their flaws.. just the opposite. All the same, it'd be nice if people would not be so quick to blame the equipment.
Old 03-20-2014, 5:50 PM
Ghstwolf62's Avatar
True and agree.
Every time I think I'm getting a good handle on this thing I find something else new to learn about it. It sure is different. Its been fun though, mostly.
KJ4KFW
Old 03-20-2014, 6:31 PM
Why does Sentinel not have any of all the Federal Agencies like the FBI in the CT listing?
Old 03-20-2014, 6:38 PM
sfdf's Avatar
It does. Click on any county and the go to Nationwide or statewide and it is all there.
Old 03-20-2014, 6:48 PM
The FBI'snot there
Old 03-20-2014, 7:05 PM
sfdf's Avatar
The FBI'snot there
Because there is non listed for your State. See the wiki for more info
FBI Frequencies and Database Listings - The RadioReference Wiki
Old 03-21-2014, 3:49 PM
harryshute's Avatar
Well I finally got mine running on the system I wanted. I should have gone back to start over long ago. All my tweaking seemed to make it worse. I agree the radio is a good one but it has been a steep learning curve for me. What did help was knowing Sentinel from the Home Patrol. I also got some good hints from the Easier to Read Manual online.
All the tips suggested were good to know. Especially checking the delete favorites lists on the software.
Old 03-21-2014, 4:25 PM
Ghstwolf62's Avatar
I'll throw this in again for any newcomers.
This gentleman has done some excellent in depth "How To" videos on virtually every aspect of the 436/536.
I highly recommend watching his videos either in their entirety or specifically to address many possible problems and for general knowledge.
He is K4DPS at K4DPS - YouTube
KJ4KFW
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
