Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 04-13-2014, 1:45 AM
Default HP-1 "SD Card" error - any ideas?
My HP-1 will not boot. It briefly flashes "Homepatrol-1" on the screen then displays the SD Card Error message. Tried different cards with no luck. When connected to the computer via USB the card shows up fine - reads/writes/etc. but Sentinel will not see the scanner. Tried the reset button - no change.
Any other ideas?
Old 04-13-2014, 1:55 AM
Nevermind - figured it out. Mods - you may delete this thread.
Old 04-13-2014, 7:05 AM
dmg1969's Avatar
Just a suggestion. When you come back and post that you found the solution or figured it out...you may want to say how you fixed it. That could help others out and not necessitate them starting their own thread.
I get that on occasion with my HP-1. Generally unplugging the power for 15-30 seconds does the trick. Only once did I have to reseat the SD card.
Dave
My Scanners: Uniden HP-1, Uniden Bearcat BC125AT and Uniden Bearcat BC355N
Old 04-13-2014, 11:37 AM
It wasn't a big deal. When I launched sentinel to reinitialize the card I didn't check the "show all drives" box so Sentinel didn't show it. When I did that I could see the HP-1 card and install the software.
Old 04-13-2014, 11:18 PM
Another thing to look for on my Hp-1,the sd card would sometimes find its way under the sd card slot ,sneaky little guy he was.Looked like it was in,but no.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
