Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
  #21 (permalink)
Old 04-18-2014, 5:45 PM
Originally Posted by teufler View Post
finally got it done, though its in freescan which you can load. I had a demo copy of arc xt but it has expired and it does not allowing saving or sending files. Anyway you might like Freescan. File is for zone 1, which has Oxford county aND THE THREE OTHER COUNTIES WITHIN ZONE 1. Ine file is a zipped . Unzip and you can load it. The Maine Comm will be a vhf p25 so that is the file I created. Left the system
in search mode so any talk groups will show. If you turn on vitual control, then logging, anything that comes up on the scanner will be put into a file that you can relate to later.
Can t you send this to me in Microsoft word or adobe. or you can e-mail me and RacnJason99@gmail.com
Jason Thompson
Scanner's 1- Uniden BC125, 2- BCD996Xt 1- BCT15x and a 1-Sportscat 200
Antenna's 1 - ST2 Starcraft ANT
Twitter- @MAINERADIOMAN
  #22 (permalink)
Old 04-18-2014, 5:50 PM
teufler's Avatar
In windows explorer, RIGHT CLICK, then a box opens. At the bottom it has a tab for PROPERTIES. Click properties and select the program you want. Hopefully you have downloaded 7 zip or some other unzipping program..Now once you set, in properies, all zip program extensions will always go to your unzippinmg program by default.As for slow, you are my speed as I am slowly moving around since having a stroke.. Right side is about 15% mobile, the right arm maybe 5% mobile. I typer with my left hand. The new DMA type scannerrs are a bear to learn but they do get easier. I have loaded and unloaded the memories maybe 50 times . When I got my 396xt, I was in the book and the web about every day for 2 months. Trunking p25 systems were hard at first. VHF p25 just came clear about 2 months ago. Had a question about digital p25 and digital one frequency p25.and then 800 frequencies mixed in. Found out that the radios are smarter than the operators so they havfe all worked out.
WD0GSY
BC-396XT, BC 780XLT, BCD 296D, AOR 8000, RS-106, RS-2067,TEN TEC PARAGON,KW D-700,DR-135, VX-10,VX-7, VX-3, UV-3
  #23 (permalink)
Old 04-18-2014, 5:57 PM
after 7 zip what do I do !!!! Im going crazy here
Jason Thompson
  #24 (permalink)
Old 04-18-2014, 6:08 PM
This is his wife...I tried to help him but neither of us can get it to work. It is alerting that the file is corrupt. We tried configuring to pdf, word and cannot get it to work. Can you email the document in word, cut and paste the document. It just won't do what we want it to.
Jason Thompson
  #25 (permalink)
Old 04-18-2014, 6:15 PM
I paid 70 bucks for ARC PRO and it sounds like I wasted my money!!! Im gonna go and download pro scan and free scan
Jason Thompson
  #26 (permalink)
Old 04-18-2014, 6:24 PM
It won't even let me open proscan
Sent via Tapatalk from my Samsung Galaxy Note 3
Jason Thompson
  #27 (permalink)
Old 04-18-2014, 7:25 PM
Ok I got proscan and free scan!!! It opens now on Free Scan.. It was zip file!!! I coulndt open them zip files up. So now its set up to open all zip files from now on.. Do I have to go home and connect my scanner to the and download from there!!!! Im in the Woodstock Bryant Pond area so I can work them zones if anyone is ok with that!!!. Im sorry I got pissed.. I have bipolar!!! so I have a short fused person
Jason Thompson
  #28 (permalink)
Old 04-18-2014, 10:35 PM
Let's try another approach:
1. Start your ARC-XT Pro
2. Click the Internet Tab at the top and drop down to Radio Reference and click on Radio Reference. The RadioReference WebService Window should appear.
3. Enter your Radio Reference User Name and Password, then click the Connect button
4. Go to the State drop down combo box, scroll down to Maine.
5. Click the yellow Trunk Systems Button
6. Go to the Trunk Systems drop down combo box, click on Maine State Communications Network (MSCinnBet) /P25
7. Check the checkbox in the left pane beside Sites: 18
8. Check the checkbox in the right pane beside Talkgroups: 4
9. Click the green Import button (the "stuff" is now in the browser)
10. Close the RadioReference WebService Window
You should be good to go and proceed with programming (sending) this to your scanner as you have with any other system.
It appears this is a new system with only four talkgroups active, those being assigned to radio technicians. So there probably won't be much to hear.
Programming these newfangled scanners to receive newfangled radio systems can be trying to anyone regardless of fuse length. Things not going right in the beginning are "par for the course", which most of us have experienced. So give yourself permission to make mistakes because they are going to happen. I had to spend a whole day at the golf course just to learn enough bad words to help me through this process .
  #29 (permalink)
Old 04-18-2014, 11:05 PM
I GOT>>>> LETS HAVE A PARTY!!!!!!!!!!!!! WHO IS THE MAN???? Teufler IS THE MAN!!!!!!!!!!!! THANK YOU and now Im off to bed!!!!!!!
Jason Thompson
  #30 (permalink)
Old 04-18-2014, 11:16 PM
teufler's Avatar
LIKE THE GROUP KEPT SAYING, KEEP AT IT, ITS A GOOD SCANNER, DON'T give up on yourself. We have all been there, intimadated with the radio, software, and just the whole learning curve. Now you have some working files that you can build on and with. With you antenna at 100 ft, agl, you can expand your reception greatly..You should be able to get New Hampshire and Boston, Ma. Also you are on a flight path coming back from Europe so there are airways listening, military stuff. Lately I have been scanning for military aircraft. Thru Freescan, Virtual Control, logging and then go to sleep. Let the radio listen for you, then in the morning, you have all the mp3 files that you can listen too.
WD0GSY
  #31 (permalink)
Old 04-18-2014, 11:25 PM
Ya. I have been playing with the dxing. I hear alot in the air and will hear alot when I go higher on my antenna.. I had the BCTX15's and thought it would be a simple switch to the 996xt and its not. But I wanna get the most out of my radios thats all!!! THANK YOU TO ALL, Sorry to Piss some off. Sorry to make 300 threads Mike.. Im just sorry to all!!! Now lets play!!!
Jason Thompson
  #32 (permalink)
Old 04-18-2014, 11:27 PM
I also left all them MS COMM FREQS on ALL not just digital like you said and now we just sit and wait.. GOOD NIGHT YA'll
Jason Thompson
  #33 (permalink)
Old 04-19-2014, 12:20 PM
There's no real harm in leaving all of the sites/frequencies "on" (or being scanned). If you are out of range, the scanner keeps on going.
You are very fortunate to have a real high antenna site allowing you to pull in distant comms. I should only be so lucky.
  #34 (permalink)
Old 04-19-2014, 1:00 PM
10.4 haven't heard much yet. But give it time
Jason Thompson
  #35 (permalink)
Old 04-20-2014, 12:40 AM
lost_in_maine's Avatar
Originally Posted by ofd8001 View Post
Let's try another approach:[INDENT] 1. Start your ARC-XT Pro
I been sending a lot of submissions for MSCOMMNET this week, so I recommend checking regularly to see the changes..Still a lot of bad info in there, but hopefully we will get it fixed soon..
Doug
BCD536HP HP-1 x2 BCD996XT
BCD396XT BCD-396T BC9000XLT
ST-2 x3 WBD-40 Discone Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
  #36 (permalink)
Old 04-20-2014, 9:51 AM
Thanks DOug.. YOU THE MAN
Jason Thompson
  #37 (permalink)
Old 04-29-2014, 4:54 PM
In FreeScann what does it mean to Lock the system???
Jason Thompson
