Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 04-20-2014, 8:31 PM
Default 996T buttons not working.
Hello, I have a Uniden 996T that all of a sudden the time the front buttons don't work 99% of the time. The 3 knobs work but no buttons. I did a restore and nothing, a few times if I unplugged it for a little bit and the buttons would work once or twice. I searched the site for answers but didn't find anything.
Any help would be greatly appreciated.
Thanks John
Old 04-20-2014, 8:57 PM
Also, I can use the button function with the scanner hooked up to the computer using Proscan. Thanks
Old 04-20-2014, 11:40 PM
W8RMH's Avatar
Sometimes the keypads wear out after a while.
SKYWARN SPOTTER Home Patrol-II BCD996XT BCD396XT Bearcat IV
Columbus Police Live Audio Feed
Old 04-21-2014, 4:12 AM
I had this same problem with my BC15XT, and I've read here on RR of other cases of it happening. What it turned out to be was the ribbon cable that connected the display was losing contact. I corrected it by opening up the scanner, and reseating the ribbon cable connections, and it worked fine after that.
Uniden BCD536HP - Yaesu FT-60 - Kenwood TM-281 -Vertex FTL-2011 - Vertex VX-3000 - Yaesu FT50R
Old 04-21-2014, 5:04 AM
Sounds like a ribbon cable issue.
You can try this, however, if the ribbon cable is the issue, this will not work.
Hold 0, 3 & Hold then press Power when the scanner is off, this should enter the Keypad test. However, if the keypad is not responsive, then like I mentioned, you will not be able to access this Keypad test.
AOR AR5000+3 & SDU, AR8000, Icom R71A, R7100, PRO2004, PRO2006, PRO43, PRO96, PRO2096, BC785D, HP1E, 396XT, 996XT, 436HP, 536HP. Probably missed some gear. Man, I gotta get rid of some of this stuff!
Old 04-21-2014, 7:08 AM
Thanks for the reply, I thought it may be a ribbon cable issue. I'll open it up and check the ribbon cable. Thanks for your help.
John
Old 04-21-2014, 12:51 PM
Thumbs up
Thanks for the help, that was the problem.
Old 04-21-2014, 1:08 PM
Glad you got it sorted.
I have not looked at the ribbon cable in these radios yet, have quite a few of them, however, would some hot glue keep things together a bit better??
Or was is just a questionable installation of the ribbon cable to begin with?
Old 04-21-2014, 5:00 PM
I think maybe just vibrations loosened the cable. I wouldn't glue it, it's easy to get to and re-seat the ribbon cable.
Old 04-22-2014, 1:07 AM
You're most welcome. Glad to be of assistance.
Old 04-22-2014, 1:08 AM
My radio had hot glue on it, but still developed the problem.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
