Toggling between ID Scan or ID Search does what exactly while scanning a trunk system?
X xrorx Member Premium Subscriber Joined May 3, 2014 Messages 69 May 15, 2014 #1 Toggling between ID Scan or ID Search does what exactly while scanning a trunk system?
S SB-Wi Member Premium Subscriber Joined Jun 20, 2011 Messages 297 Location Eastern Dane Co May 15, 2014 #2 ID Scan will only stop on talkgroups you have programmed. ID Search will stop on ANY talkgroup unless it is locked out--useful for new talk groups or anything not in the database.
B boycesm Member Joined Oct 14, 2010 Messages 58 May 15, 2014 #3 xrorx said: Toggling between ID Scan or ID Search does what exactly while scanning a trunk system? Click to expand... If you have entered or the scanner is already aware of Talkgroup ID's it will only "scan" for those ID's. ID Search looks for ones you don't know but also displays the Talk groups in which you do know. Hope that helps.
X xrorx Member Premium Subscriber Joined May 3, 2014 Messages 69 May 15, 2014 #4 Thanks - very clear answers.
