Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 05-29-2014, 8:24 AM
Default Headphone Jack Repair
I have a BCD996T and it has the headphone jack problem where the internal speaker and the rear speaker jack does not work, yet the headphone jack does work.
Will Uniden still repair this problem?
Can they upgrade the firmware at the same time?
Old 05-29-2014, 8:39 AM
I'm sure that it can still be repaired, the flat rate fee for that (and most) scanners is $49.50.
If you included a note to upgrade the firmware they would probably do that also.... if not, it's easy enough to do that yourself (if there are any available updates for your scanner).
Check Uniden's repair page here for details and shipping instructions:
Product Repair
Old 05-29-2014, 6:21 PM
wtp wtp is offline
Default cheap fix
my 396t has the some problem once and a while. especially after using the jack.
a cheap fix would be to use computer speakers. with my radio it even sounded better.
Old 05-30-2014, 5:36 AM
Thanks for your replies.
I will send it in for repair. I don't have room for an amplified speaker and the internal speaker, if I recall correctly, is good enough for communications.
Tags
bcd996t headphone jack, upman
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
