Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 05-31-2014, 11:27 PM
Default how can I keep the backlight on at all times?
I set it to Infinite and no light at all I set it to squelch and it only stays on for like 5 seconds or so.. How can I make it on at all times? 1.11.10
Old 05-31-2014, 11:40 PM
bryan_herbert's Avatar
When its set to infinite, you turn it on and off manually with the power button, there's no timer.
Bryan Herbert - KE6ZGP | WQKW261
http://twitter.com/ke6zgp
http://bryanherbert.com
Old 05-31-2014, 11:53 PM
Thanks a lot for the info.. it worked.. Solved
Old 06-01-2014, 12:01 AM
thanks
Old 06-01-2014, 1:30 AM
teufler's Avatar
tHE FILE SENT TO YOU HAS BACKLIGHT AT INFINITE.
WD0GSY
BC-396XT, BC 780XLT, BCD 296D, AOR 8000, RS-106, RS-2067,TEN TEC PARAGON,KW D-700,DR-135, VX-10,VX-7, GT-3, VX-3, UV-3
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
