Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 06-01-2014, 12:09 AM
Default Antenna question
Antennacraft ST2 or RS Model: 20-176? I monitor P25 450-460 and analog 154-159. which would you guys recommend? I have a 35 foot tower to put it on..
Old 06-01-2014, 1:29 AM
teufler's Avatar
I use a dual band diamond clone antenna. 18' tall. It works for all , low band through 950 mhz. The ST2 works fine too though they are flenzy and at height, they will get wind, and possibly ice build up. Come spring, you wiull have good metal for tomato plants possibly. My clone is a WORKMAN brand and its been up for 15 yrs. I did have one at 225 ft on a water tower but one winter did it in. The mast clamps were too light for the wind load. This antenna is made for the ham bands so its cut alittle lower than PS but for monitoring it works fine
WD0GSY
BC-396XT, BC 780XLT, BCD 296D, AOR 8000, RS-106, RS-2067,TEN TEC PARAGON,KW D-700,DR-135, VX-10,VX-7, GT-3, VX-3, UV-3
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
