Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 06-06-2014, 11:47 AM
Default BCD996XT Enabling/Disabling Group Quick-keys
Hi all,
Is there a fast way to enable or disable group quick keys? Here's the situation.
System QK1 is for my local area's conventional systems (Five small townships in NJ, each with one or two PD and one or two FD channels). GQK 1 is police, GQK 2 is fire and EMS, but GQK 3 is for towns that are just a little bit further away, and that I don't always drive into, nor am I interested in hearing them until I'm about to go there.
I have about 20 different system QKs set up for different counties/agencies, and when I'm in my home region I usually have 4 enabled -- SQK 1 for local conventional, SQK 2 for my next town over on the statewide NJICS 700 MHz trunked system (Fairfield, NJ), SQK 3 for the next town over in the other direction on an EDACS system (Verona, NJ) and SQK 4 for the NJ state police 4-COMM talkgroup. This covers patrol for every place I routinely drive through.
With all four of these SQKs enabled and scanning, how can I QUICKLY and EASILY turn on or off GQK-3 (towns of Little Falls, Totawa and Wayne) in SQK-1 (Local/Conventional)?
Cheers & 73
Peter,
W2IRT
Old 06-06-2014, 12:39 PM
captclint's Avatar
Mentor
Basically, there is a moderately easy way, and then a not so easy way.
To toggle a Group quick key on or off while scanning the system, quickly press Func then press the number key assigned to the group.
To toggle Group quick keys on or off in another system press and hold Func to 'lock' Function mode. Scroll to the (enabled) system that contains the (enabled) group you want to turn on/off then press the corresponding number key(s). Press Func twice to 'unlock' Function mode and resume.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 06-06-2014, 12:42 PM
JoeyC's Avatar
You have 100 SQKs available. You stated that you are only using 20 of them. I would put the group of freqs in question into its own system with its own unique SQK separating it from your SQK 1 altogether.
Old 06-06-2014, 2:05 PM
Yeah, I think this is what I'll have to do. With 0-9 already used, it's still a bit of button-pushing (three tiny buttons to push while driving), but better than the convoluted process of hold, scroll (while looking at a display), etc.
What' I've been doing now is disable the other currently-enabled SQKs, function-3 to enable the desired group, then re-enable the others. All are single-keypress system QKs. So, 2-3-4-HOLD-FUNC-3-2-3-4-SCAN. Just making another SQK sounds a bit easier--bit will entail renumbering SQKs to make the transition logical.
Cheers & 73
Peter,
W2IRT
Tags
gqk, sqk
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
