Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 06-30-2014, 4:44 PM
Default Loading LTR Channels on the BCD 436 HP
Does anyone know how to program the LTR channles on this scanner?
I have used both the Sentinel Software and the Trial Version the Buetel Software.
using the Sentinel Software scans, however does not pick up anything.
using the Buetel Software the scanners indicates "nothing to scan"
Thank you
Old 06-30-2014, 5:05 PM
UPMan's Avatar
Uniden Representative
Create a Favorites List.
Create a LTR System in that FL.
Create a Site for that System
Put the frequencies/LCN's in the site.
Unless you want to just search the system (ID Search), create a Department.
Program the channels you want to hear in the Department.
Uniden Product Ninja
Professional Scanner Developer
Old 06-30-2014, 5:17 PM
AC0RV's Avatar
Smile Mutliple sites
I think may be related question.
What should I do when the system multiple LTR Sites. Do I need to create a separate system for each system on the 436 HP.
Thanks.
May the LORD watch over you and your Family.
David F AC0RV
Skywarn # M187201
Old 06-30-2014, 5:25 PM
UPMan's Avatar
Create a separate site within the system for each LTR site.
See AirTime Services (KC) Trunking System, Kansas City, Multi-State - Scanner Frequencies in Sentinel for an example (look in Jackson County's County Systems, it is the first system listed).
Old 06-30-2014, 5:33 PM
AC0RV's Avatar
When I downloaded them system in the database, It has created separate sites for that system, Does follow the same rules as the other mutli site systems ?
David F AC0RV
Skywarn # M187201
Old 06-30-2014, 8:48 PM
Hello Still having issues with the LTR on the BCD 436 HP Scanner
where is the option to put this data in. Every time I download it in either the Sentinel Software or the Butell I don't see any options to place this info
I don't know why I am having an issues with this. I am usually fairly good with technology.
Old 06-30-2014, 9:38 PM
UPMan's Avatar
Maybe watch https://www.youtube.com/watch?v=ECOUceSdVCo
Not sure exactly where you are getting hung up, so maybe that will help.
Old 07-01-2014, 3:49 PM
Yest the youtube helped and I loaded the frequencies into a favorites list.
there are listed as conventional. How do I change them into LTR?
The scanner is scanning, however nothing is being picked up.
Old 07-01-2014, 3:53 PM
UPMan's Avatar
When you create the system, you need to set it as an LTR system, not conventional. The first dialog box that pops up and asks for the system name has a drop-down list for system type. The default is P25 Trunk, so I'm surprised it made it to Conventional w/o you seeing LTR in the list (which is the selection just above Conventional).
That said, if there were traffic on the system, you'd hear it, even though you've programmed it as conventional. It just wouldn't trunk track.
What specific system is it you are trying to monitor?
Old 07-01-2014, 6:20 PM
First Thanks for the Help.
The system is in Chester County, Pennsylvania
I am using the Chester County/Government frequencies.
Old 07-01-2014, 7:21 PM
Hello
I have loaded almost all the frequencies and don't here a thing.
it indicates scanning, but not picking anything.
I the National Data base I do pick up traffic, mostly SEPTA..which is simulcast with the Philadelphia PD.
Range is set at 25 I have tried longer ranges with negative results.
Old 07-01-2014, 7:40 PM
AC0RV's Avatar
Smile
You should have when you set your location and one for each department and./or trunk site as well.
So check them both.
David F AC0RV
Skywarn # M187201
Old 07-01-2014, 11:53 PM
If you're talking about this system: Chester County Trunking System, Various, Pennsylvania - Scanner Frequencies, the RR database shows it as LTR Multinet which, as far as I know, is not capable of being "trunk tracked" by the 436 (or any currently available scanner). If you loaded it from the database, that may be why it programmed as "conventional" as a default when presented with a non-compatible LTR system. However, as others have said, you should still be able to hear traffic on the frequencies, you just won't be able to follow/track conversations.
-Mike
