Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support - For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 07-29-2014, 9:07 AM
Default 436HP Logging
I see a scanner log mentioned in Sentinel, but it's always empty, and I don't see any way to enable it in either Sentinel or the scanner menu. I would like to enable logging so I can see which frequencies/systems are getting the most traffic. How do I do this?
Old 07-29-2014, 11:34 AM
Sentinel doe not have logging capabilities.
ARC 536 Pro will do both Virtual Control and logging of hits. (While the name says "536" it does work on the 436 models).
ARC536 software for Uniden BCD536HP and BCD436HP scanners Sentinel HomePatrol Home Patrol free demo software Uniden 436 536 HP
Old 07-29-2014, 12:00 PM
joeuser's Avatar
You can get free logging with Scanner Screen
-HP-1&2,BCD436HP,996XT,396XT(2),396T.BCT15X(5).BC250&2 96D,780XLT(3).GRE PSR 600(2),800.Pro-197(3),164(2),163,2006(2),2001,42,37,21A.TRX-100XLT.DX-440.DisCone,CenterFire/Multi-Band,ST2,Procomm Spider.
Old 07-29-2014, 1:20 PM
tampatracker's Avatar
Where can we find that?
BCD436HP, 396XT, PSR-800 , PSR-500, BC 250D, BC 245XLT, ICOM R-75, YAESU FRG-8800, WS 1080.
Old 07-29-2014, 2:01 PM
Mentor
Check here for the download.
The thread itself is quite lengthy.
Steve
BCD536HP-BCD436HP-BCD325P2--Home Patrol 2(E)-Home Patrol 1(E)-BCD396XT(2)-PSR500-BCD396T-BCD996T-BC780XLT
Old 07-29-2014, 3:16 PM
If I have to have the scanner connected to a laptop to do logging, that's not very useful when out and about with the 436HP. I could see the utility of doing that with a 536 set up as a base station, but going that route with a 436 is pointless.
Meh.
Old 07-29-2014, 4:21 PM
joeuser's Avatar
IKR! I'm sure someone makes a handheld that saves the log in the unit! Probably a similar price to the 436!
Old 07-30-2014, 11:53 AM
Default Discovery mode
Trunking Discovery and Conventional Discovery are what do the logging on the X36HP scanners. This explains how to set it up, review it, and export it to Sentinel. This is also on page 60 of the Owners Manual.
Easier to Read BCD436/536HP Digital Scanner Manual Discovery Mode
Uniden BCD436HP
Old 07-30-2014, 12:00 PM
joeuser's Avatar
Right but I think from the OP he wants to see what gets the most use of what he's listening to. He's not looking for logging of undocumented fregs/tg's
Old 07-30-2014, 12:04 PM
He referred to the log mentioned in Sentinel, and that is the Discovery Log, so I referred him to that. I guess I misread his intentions.
Uniden BCD436HP
Old 07-30-2014, 5:20 PM
joeuser's Avatar
You may be right, guess we'll see if the OP comes back with more
Old 07-30-2014, 7:09 PM
I'm looking to log date/time/frequency/location whenever squelch opens, so I can get a better idea of which channels/systems are most active. Talkgroup ad ID as well if it is a trunked system.
Incidentally, if all scanners did this and the info was uploaded to a common database, it would make an interesting Google Earth map overlay...
Old 07-30-2014, 8:32 PM
I am not aware of any scanner that does this and stores it on the scanner itself.
Uniden BCD436HP
Old 07-30-2014, 9:06 PM
I believe the newer GRE built scanners can do this. Also there were older Analog Bearcat scanners that could log hits, but not time or date as I recall.
The problem with logging hits in the GRE units it was killing the RAM chips with so many active writes to them. If you really logged a lot of info, the RAM chips were not lasting.
Best to use a 3rd party software for this, but this does not help for a portable or mobile device so much.
It is rather interesting that just looking at the audio recordings how short most transmissions are for Public Service communications. Fire dispatches tend to be the long duration recordings and they are still not that long.
AOR AR5000+3 & SDU, AR8000, Icom R71A, R7100, PRO2004, PRO2006, PRO43, PRO96, PRO2096, BC785D, HP1E, 396XT, 996XT, 436HP, 536HP. Probably missed some gear. Man, I gotta get rid of some of this stuff!
Old 07-30-2014, 9:32 PM
Logging hit count information on a portable scanner while out and about is unconventional.
There is a round-a-bout way of accomplishing this. Simply set the scanner to record all the transmissions. Then from downloading the recordings and seeing the file header information, some idea could be determined. Yeah it will be tedious and will definitely test the level of determination to have this information.
Old 07-30-2014, 10:02 PM
The main motivation is to prune out stuff that isn't active, so I can refine channel selections better. Also, logging CC hits like that could give better info on unknown/new systems.
Old 07-30-2014, 10:06 PM
That's not an issue with removable flash cards with wear-leveling controllers. If you did wear a card out, a new one is $10 or so. Also, writing log entries causes less flash RAM wear than audio recording.
Old 07-30-2014, 10:31 PM
joeuser's Avatar
Suffices to say, if you need basic logging Scanner Screen is free & does well for my needs. Good luck to the OP.
Old 07-30-2014, 10:54 PM
The GRE units had RAM failures due to the number of writes and they were surface mount chips that required unsoldering and resoldering.The number of hits on an active system can get rather high if left running continuously.
Removeable cards make things a bit simpler, but non of the non volatile memory is immune from funny stuff after many writes.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
