Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 08-08-2014, 11:55 AM
Default Does it HAVE to Blink?
Whenever my 996XT stops on a channel, the display starts blinking. I don't mind changing colors, but is there a way to stop the blinking?
FF
Old 08-08-2014, 12:00 PM
Kingmobileaudio's Avatar
It's an alert programming that you put for that channel.
Old 08-08-2014, 12:05 PM
NHdave's Avatar
Yup, that's user programmable, also not the default setting so you must have changed the setting for it, you can also have it change colors for certain channels.
________________________________
BCD996XT, Pro 106, Pro 2053, BC350A, BC120xlt
Old 08-09-2014, 9:37 AM
Thanks. Using ARC XT I see 4 alert columns. One of these must control the blinking but it is not clear what each one does. Looks like Alert Pattern: On - Slow - Fast controls the blinking. Lacking description in the ARC documentation, Uniden documentation and the Easier to Read documentation. I must be slow.
FF
Old 08-09-2014, 10:47 AM
FF
IIRC, On = On Solid, Slow = Slow Blink, Fast = Fast Blink
AOR AR5000+3 & SDU, AR8000, Icom R71A, R7100, PRO2004, PRO2006, PRO43, PRO96, PRO2096, BC785D, HP1E, 396XT, 996XT, 436HP, 536HP. Probably missed some gear. Man, I gotta get rid of some of this stuff!
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
