When a 996 fails to stay on a channel, where the delay setting has been activated, does this mean the weather checker or close call is activated? The radio won't stay on the channel/talk group to hear the end of the conversation.
double check on the delay setting, if it is negative it will give a sound sample and then move on like you said.
there is negative and positive numbers so, -2 lasts for two seconds and will scan no matter what and with 2 will wait two seconds after the transmission ends.
Since I'm helping a friend here, I found out which model. It is the 396XT. I thought he had the one I mentioned. When I went over to eyeball the radio, I learned of the model number and that he had the squelch cranked too high. Problem solved.
