Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Owner Tech Support
Uniden Owner Tech Support For current owners to get support with their scanners from existing or past owners. If you do not own or have model experience please restrict yourself to the other sub-forums.
Old 09-01-2014, 7:49 PM
se's Avatar
se se is offline
Default STARTECH.
Hello All.
Do I need this cable that I am providIng a link to in this message in order to be able to use the Virtual Control in Butel's ARC536PRO FULL version software? Can I buy this item from The Source store in Canada?
Thanks Sheldon.
The link will be in my next message.
Old 09-01-2014, 7:56 PM
se's Avatar
se se is offline
Default HERES THE LINK.
http://www.amazon.com/StarTech-com-1...iglink20662-20
i hope this link isnt messed up.
Sheldon.
Old 09-01-2014, 9:15 PM
lost_in_maine's Avatar
I bought a StarTech Cable for my 536, and using it with Proscan...also tested with Arc536
Only difference in the link you posted and this one is, it's only 1 foot long...mine is 3 feet,
Amazon.com: StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI, Black (ICUSB232FTN ): Computers & Accessories
Doug
Doug-BCD536HP HP-1 x2 BCD996XT
BCD396XT BCD-396T BC9000XLT
ST-2 x3 WBD-40 Discone Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
Old 09-01-2014, 10:18 PM
se's Avatar
se se is offline
Default HI.
Hi.
Cool. So does this cable allow you to use the virtual control in the ARC536 software? Does it actually replace the usb cable?
Sheldon.
Old 09-01-2014, 11:43 PM
Originally Posted by se View Post
Hi.
Sheldon.
Yes, it connects to the serial port on rear of 536..
You would still use the supplied USB cable for programming, and firmware upgrades...
Old 09-02-2014, 12:14 PM
Hi.
Sheldon.
The cable in your link is not a NULL cable.
You can use that cable but will also need a null modem adapter or null modem cable with the correct gender on each end to connect to the rear port on the 536 and to the port on the cable in your link.
If you get the cable in your link, also purchase a female to female NULL modem cable.
That way you can use the startech serial adapter for normal serial devices without the NULL modem cable and then add in the NULL modem cable when you want to use the rear port on the 536 with ARC536.
Old 09-02-2014, 12:27 PM
You want this one, 1 min install. Sucks having to keep the front plugged in for updates, Uniden really screwed this radio up.
Old 09-02-2014, 8:43 PM
se's Avatar
se se is offline
Default Will that be (all) i need?
Hi OHIOSCAN.
So is the item in your link all I need?!
Sheldon.
Old 09-02-2014, 10:32 PM
Hi OHIOSCAN.
Sheldon.
Yes..no need for any adapters, is working solid on my pc now for 4 days straight, no issues...
I downloaded the driver from the FTDI website, the one supplied with the cable, was a little outdated...
Old 09-03-2014, 11:50 AM
se's Avatar
se se is offline
Hi.
Ok Thanks.
Sheldon.
Old 09-03-2014, 12:50 PM
Default Startech
Hi OHIOSCAN.
Sheldon.
Yep, you will still need the Uniden front cable for programming.
Old 09-04-2014, 7:53 PM
se's Avatar
se se is offline
Default VIDEO.
Hi.
Do any of you know if there is a/are video(s) showing installing and use of this type of cable to a BCD536HP?
Thanks Sheldon.
Old 09-04-2014, 8:30 PM
Hi.
Thanks Sheldon.
Was fairly simple to install....Not sure of any video's, but all I did was install the driver,
then went into Sentinel, Edit Menu, Edit profile-location settings to change GPS baud rate to 115200...
Then make sure you write to the radio after....
If you omit this step, and then you write to the radio after, it will Default back to the previous rate in the profile which doesn't work... I also set my baud rate to 115200 on that comm port throught Windows device Manager..
I plugged it in, and Proscan saw it right away...same with ARC536
You still need to keep the supplied USB cable for editing of the db, and firmware upgrades
Old 09-08-2014, 4:41 PM
se's Avatar
se se is offline
Default CABLE?
Hi All.
Will this cable do, for me to use the VC in ARC536PRO? Im hyst making sure Im getting all that I need.
Thanks Sheldon.
Buy the StarTech.com 1 Port USB to RS232 DB9 Serial at TigerDirect.ca
Old 09-08-2014, 5:22 PM
Hi All.
Thanks Sheldon.
Yes, that will/should work...
Old 09-10-2014, 9:47 PM
se's Avatar
se se is offline
Default Nextech serial to usb cable.
Hello All.
I bought a 2 feet Nextech serial to usb cable today from The Source by Bell and it seems stubborn to connect to the port at the back of the BCD536HP (as if its not the right size). Is there an adapter I need to buy also? Is Nextech a good brand of this type of cable?
Old 09-16-2014, 12:29 PM
se's Avatar
se se is offline
Default HI.
Hi All.
Sheldon back again. Is the Startech cable that I need Male to Female or Male to Male? Im gonna order one online and I just want to make sure.
Thanks!
Old 09-16-2014, 2:04 PM
Hi All.
Thanks!
It is a DB9-male and terminates with USB at the end..
This link I sent you before is ALL You will need..And Amazon does ship to Canada...
Might even find it on Amazon.Ca
Old 09-16-2014, 3:28 PM
se's Avatar
se se is offline
Default HI.
Hi.
Will this work?
Startech ICUSB232DB25 USB to RS232 Serial Adapter Cable - DB9/DB25, 3 feet, Male/Male at TigerDirect.com
I prefer not to order anything from amazon.com
Sheldon.
Old 09-16-2014, 5:01 PM
https://www.google.com/search?btnG=1...TDI&gws_rd=ssl
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
