what is the difference. Its tough to sit down antry to read Mikes maunyulls and even harders to read the bible!!!
From the 396XT Easier to Read manual...
Set Hold Time sets (in seconds) the amount of time the scanner will scan the system before moving on to the next system. All (unlocked) channels will be scanned at least once regardless of this setting. The scanner moves to the next system after the hold time expires, any current transmission ends, and the channel delay time expires. The default setting is 2 seconds for each system.
Tip: set your systems to 0.
Scroll to 'Set Hold Time' and press E/yes.
Enter the hold time (0-255 seconds) you desire and press E/yes to save and exit.
Set Delay Time sets the delay (in seconds) the amount of time the scanner stays on a channel after the transmission has ended before moving to the next channel. A negative delay will force a resume after that number of seconds. This setting applies to all channels in the system. You cannot set the delay on a 'per channel' basis. The default setting is 2 seconds.
Scroll to 'Set Delay Time' and press E/yes.
Scroll to the desired delay time (-10, -5, -2, 0, 1, 2, 5, 10, or 30 secs.) and press E/yes to save and exit.
