f2shooter
Morning all,
Now that I've spent some time working with my 436HP I am starting to figure out what questions I want to solve in daily usage. I'll probably start carrying it around on out of area travel a good bit and would like to use the GPS function to automatically update location information. What item do I need to purchase to do so as easily as possible? I'm not inclined to do much button pushing while driving so it needs to do the work on its own as much as possible. I've seen references to GPS use but don't know if there is an accessory specific to the 436 or if there are several options that can simply be plugged into it. What are others of you doing or are you using a different function such as Autolocate to update location? Thanks.
Otis
Otis
