What do you mean "RF environment"? In my situation I'm almost certain it's a LSM issue. If I listen to Site 1 I get garbled audio and most transmissions are unlistenable. Site 1 consists of 6 transmitters and my house is about right in the middle of those transmitters. If I listen to Site 2 which is about 15 miles away and only has 3 transmitters, I don't have the audio problems. So I'm pretty sure LSM is the culprit.
If you primarily use the HP2 as a stationary radio, you may be a good candidate for trying a small 3 or 5 element yagi or even better, a 700 MHz corner reflector that has solid panel reflectors to minimize signal ingress from the backside.
If you are handy at building things, you could probably slap together a small yagi pretty easy using plans found on the internet. A corner reflector at 700 MHz should also be pretty easy to build.
You don't really need either of these antennas for the gain they offer but rather the directional properties they both offer.
Something with the narrowest beamwidth you can find is what you are after if you are sitting in the middle of all the towers.
Aim it at the nearest tower that also has the greatest spacing in degrees from the other tower sites for your system of interest.
I've actually had good luck with a more distant system that was mostly blocked by trees (especially in the summer) using a direct aim. I found that I could get a much better signal by aiming at a nearby large building which picked up the reflection of the real signal. The aim was far enough away from the true signal that it nulled out the true signal and only picked up the reflection. When the leaves fell in the fall though, I had to play with aim again as the trees no longer offered any attenuation. That one worked best with a corner reflector.
Using a 12 element yagi, I had luck with a simulcast site by aiming the yagi 180 degrees off of true aim which blocked all but the strongest signal.
I've also had good luck using a yagi or corner reflector aimed maybe 20 degrees off of true aim. That was a system with all transmitters in one direction from me though. I was able to pick the northernmost tower and aim about 20 degrees further north than the tower. That 20 degrees was enough to null the other two towers signals and gave me perfect reception.
I'd try and build a yagi for testing. It does not need to be pretty looking but may give you an idea if a directional antenna will help.
The goal is to try and get signal from one tower only. If you have other 7/800 MHz sites in other directions, a yagi at those frequencies can be rotated with a cheap tv antenna rotor.
It took me a lot of experimentation before I found the best solution both in the radios used as well as the antennas.
The use of a directional antennas helped me more than anything though.
It also added the benefit of pulling in distant sites that I could not even detect with an omni made for just the band of interest.
Figured I'd throw this out there as I know directional antennas have helped many overcome simulcast distortion when nothing else worked.
Another idea is if you have an old TV antenna laying around. You would mount it vertically and try that. They are basically wideband yagi's but horizontally mounted for TV. Of course it needs to have been made to cover the old UHF TV band that went up to channel 83. A TV antenna may not have as narrow of a beamwidth that you really want but it may tell you if a directional antenna will work.
When RadioShack was still around, they sold UHF only TV antennas that could be mounted vertically by drilling two new holes through the aluminum boom. That gave you a directional antenna that covered from around 400 to 900 MHz or so. They were kind of a mix between a corner reflector design and a yagi. They had the large reflector wings on the back that you folded out. But the main boom was more of a yagi design. I guess that all helped give them their wide bandwidth needed for tv.
