richee2000
Communications Professional
i have the 436... having issues picking up VHF and some UHF trunking systems, which come in fine on my BC396t hand held. If I purchase a 536, will I have improved reception ?
agreed on the P-25 performance... and it may have something to do with the problem properly decoding "simulcast" p-25 systems...and i also have issues with phase II p-25 systems (P0, P1) ... same as you said... alot of broken audio, etc. any clue if the new whistler scanners are any better on these issues ?
I posted my findings. The site I'm having biggest problem with is listed as simulcast, but it only has one site.
The RR database only has one site listing for systems that have multiple sites on the same frequency.
i just got the 536... actually,,, it works very well...picks up most p-25 and phase II very well...air, vhf/uhf ..all good... no real complaints...speaker sounds too bassy/muddy...much better than the 436 and hp1 and hp2... what area are you in ?
I do not own a 436, but I do own the 536. There are a few discussions going on now about the 536. While I can "hear" the sytems, the current 536 firmware is not as good decoding P25 as earlier models. For example, my 996 has no problems with the Jersey City (Hudson County) system, while the 536 spits and stutters if the signal is below 3 bars on the s meter. My 996 can receive conventional VHF channels using P25 from CT. while the 536 can "hear" the data, it cannot decode it (P25).
Uniden claims to be studying the matter and developing new firmware, just as they are doing for the WiFi app - for the past 11 months! My advice is to stick with what you have and put up a discone antenna fed with good low loss cable. I like my 536, a lot, but I am very disappointed with its P25 performance.
when I had the HP2 , it did hear the NJICS system just fine..but, the other system I needed was the somerset county TRS, which it could not decode properly. And it was not all that good on VHF, UHF , 800, etc... The 536 hears those much better.
I live in Orange County and have no
problem picking up the New Jersey
Interoperability system with my 536.
As for audio I use a bearcat external
Speaker and it sounds great.
The hp-2 would not decode the system
at all.
Same antenna same location.
It was with great reluctance that I returned
It.
Was I just unlucky to receive a bad hp-2.
Only the scanner gods know the answer
to that.
