diggerodell
- Joined
- Jun 4, 2007
- Messages
- 13
where can I get driver for my bcd996p2 scanner for free scan software
thanks
thanks
thanks
thanks
Is FREEScan compatible with the P2 yet? The webpage doesnt indicate it yet
ARC/PROSCAN say they are compatible
Ok.. it arrived. Plugged it in via USB and it connected and assigned port with no additional drivers installed. Initial uploads using the beta Freescan yielded some errors I don't understand yet but it loaded the important stuff.BCD996XT does not have drivers at all. It is native serial. If you are using a USB-->RS232 converter cable, it has drivers that are certainly not the same as the drivers needed for the cable.
Will probably run this side by side with 536HP and do some comparisons this weekend. Just ordered 352HP from Jeff at Ham Station. Going to be busy with comparisons on multiple systems here in So. Calif. in next week or so.
Steve AA6IO
Are these the same drivers that I loaded when I installed drivers for the 536?
The thing I dislike about the 996P2 compared to the 996XT is the XT will keep right on running trough an engine start where the P2 shut down and restarts.
So I am guessing that the drivers I already had aboard for the 536 are the drivers that the 996P2 used when first connected.BCD996XT does not have drivers at all. It is native serial. If you are using a USB-->RS232 converter cable, it has drivers that are certainly not the same as the drivers needed for the cable.
