Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Prospective Owners
Uniden Prospective Owners - A discussion area for those interested in purchasing specific models and have questions about them.
Old 07-05-2017, 12:32 PM
Default Uniden BC125AT Antenna Upgrade
Hello all. So I have a couple of Uniden BC125AT scanners and I'm looking to upgrade their antennas to get a better signal. Preferably I am looking for an antenna that will keep the scanner portable, but I'm also interested in what antennas would be good for mounting in a more permanent location. Thanks in advance!
Old 07-05-2017, 12:52 PM
ShyFlyer's Avatar
I'm well pleased with the Diamond RH77CA.
Old 07-05-2017, 3:01 PM
the Rh77ca is a pretty good antenna. That's what i've used on my BC125at for many years.
Old 07-05-2017, 3:17 PM
Based on what I've read elsewhere that is what I was looking at already so awesome! How much of an improvement did you see with the RH77CA over the stock antenna? It only cost $26 so not like I'm breaking the bank, but is it worth the cost? I.E. is there a significant increase in signal quality?
Thanks!
Old 07-05-2017, 4:14 PM
jonwienke's Avatar
It's totally worth it. The RH77CA picks up way more stuff than the factory antenna.
Old 07-05-2017, 6:00 PM
bigcam406's Avatar
The Watson 801 is worthy of consideration also.
Uniden's BC898T BCD325P2 125AT 95XLT GRE 310 410 500 600
Old 01-13-2018, 3:49 PM
captncarp's Avatar
Smile Uniden BC125AT Antenna Upgrade
I am well pleased with the Watson 801. I have a bunch of them for different radios.
I don't like the Diamond for 800 trunked system.
Old 01-20-2018, 3:51 AM
kb6aok_1125's Avatar
I use the RS800 antenna. It works decently enough to get the job done but I am sure there are better, albeit more expensive, options out there.
Edit: BTW this is my only antenna out of all of my Handheld Scanners(2). The more expensive it is the more likely I am to lose it. What kind of logic is that?
Old 04-25-2018, 4:46 AM
iMONITOR's Avatar
+1 Great for commercial and military aircraft!
Old 04-25-2018, 8:37 AM
+1. Have one each on my 325P2 and 125AT.
Uniden BCD325P2 / BCD996P2 / BCD996T / BC125AT
Tags
antenna, antenna advice, uniden, uniden bc125at
