Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Prospective Owners
Uniden Prospective Owners - A discussion area for those interested in purchasing specific models and have questions about them.
Old 02-13-2018, 5:55 PM
milcom_chaser's Avatar
Default Post your DMR
Looking for someone(s) in the community to post any video of their 325P2 decoding DMR. Simplex would be very helpful. Looking to see, and hear the audio quality as well.
Thank you out there...
Old 02-15-2018, 11:03 PM
fdnyfish's Avatar
Uniden don't decode DMR simplex
Retired FDNY*EMS Captain
KB2MXV
Old 02-16-2018, 5:24 AM
n9mxq's Avatar
My 325p2 will. I've done it.. I'll try and get video today while I'm at work.. have both my 325 and my at-d868uv with me.
Sent from my SM-G950U using Tapatalk
Gene
Transceivers, receivers, and SDR! Oh My!
Old 02-16-2018, 5:53 AM
n9mxq's Avatar
They can be finnicky but they will do it. Scanner was in service search. But it will work just as well in a programmed channel. https://youtu.be/xFmUJO43PHI
Gene
Old 02-16-2018, 8:03 AM
n9mxq's Avatar
Here's the 325 decoding the Belvidere K9VO ham repeater.. https://youtu.be/6D4xSVUqufs
Gene
Old 02-16-2018, 8:17 AM
n9mxq's Avatar
And finally Belvidere Assembly CAP+
https://youtu.be/IYhx5CV42Uo
Gene
Old 02-17-2018, 9:15 AM
Thanks for taking the time to make those videos. I may have some additional questions for you soon.
I'll take a look at them.
Old 02-17-2018, 9:25 AM
Love the echo on the first of the two videos you posted
I've noticed when scanning a single freq DMR, if you toggle the display mode option Func + 6,
the following will be displayed:
Mode 1: ID + Frequency
Mode 2: ID + Color Code
Mode 3: ID + Slot #
I can't seem to get the radio to display both Color Code and Slot # at the same time during a service or
custom search. I have toggle tone/code search to NAC/Color Code, which at least gives me the Color Code when it's on, and DMR type when it's off.
Up on the TWiki: http://info.uniden.com/twiki/bin/vie...adeforBCDxxxP2
It says:
During a search, when the scanner stops on a DMR transmission, the following information will be displayed:
• DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
• CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
• CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), and the received color code.
• DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code.
Are you able to get the Color Code and Slot Number to display simultaneously?
Old 02-17-2018, 9:52 AM
n9mxq's Avatar
Mode 3: ID + Slot #
It says:
•DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), and the received color code.
•DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code.
I've honestly never tried. I just made the first video to prove that the 325 will do simplex. I did the other two per the original request. I don't really use the scanner much for DMR/TRBO.
Gene
Old 02-17-2018, 9:59 AM
n9mxq's Avatar
I have discovered it won't decode DMR from my Jumbospot hotspot.. found that kind of interesting.
Gene
Old 02-17-2018, 11:09 AM
That is interesting...
Old 02-18-2018, 1:12 AM
pinballwiz86's Avatar
What are you talking about?
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 04-30-2018, 8:14 AM
n9mxq's Avatar
Thought I'd post a quick followup.. After a long wait I received my Zumspot hotspot.. The 325 will not reliably decode it either.. It tries, but no soap...
Gene
Old 06-11-2018, 12:42 PM
n9mxq's Avatar
Something must have changed in MMDVM firmware. Both my 996p2, and my 325p2 will now decode both my Zumspot, and my Jumbospot...
Gene
