Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Prospective Owners
Uniden Prospective Owners - A discussion area for those interested in purchasing specific models and have questions about them.
  #81 (permalink)
Old 05-24-2018, 12:44 PM
Originally Posted by tumegpc View Post
Proprietary battery packs are costly and lose their capacity over time, and most of all inconvenient. Keeping the 436HP.
Most products that use an internal rechargeable battery pack don't use "proprietary" battery packs. They use pre-engineered off the shelf battery packs that meet the required specifications of the device manufacturer. 3.7v 3600mAh is an extremely common spec that comes in a massive number of different packages and connectors. Finding even an unbranded replacement for whatever comes in the SDS-100 likely be pretty easy.
  #82 (permalink)
Old 06-10-2018, 9:41 AM
bob-k's Avatar
Default yes you can!
Originally Posted by strandbiker1 View Post
Is the Uniden SDS100 lithium ion battery removable and able to be replaced by AA batteries? Can you operate the SDS100 from the 5 volt external port, or is that only for charging? What is the voltage of the stock battery pack?
Skip KD6JA
-The SDS100 has two ports one is for operating while not charging and one for charging!
-Go to Settings/Battery Options/Set Charge while On
-My display show at fully charged 4.21 volts
-There is a Battery save on/off
-Also the ability set a Battery Low warning were you can set the volts and type of alarm Tone/Interval/alert volume
4 oldies, Plectron, RS Pro-96 & Uniden SDS100
Support those who serve us actively or in the past! US Military, Veterans, all LEOs, FD, EMS & Emergency Management!
I'm a Navy Vet, I got your 6!
  #83 (permalink)
Old 06-10-2018, 9:45 AM
mule1075's Avatar
That would be be my guess also. It is not going to be like the slide on packs for the x00xlt series. Or the x000 series for that matter.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
